Higher compression on Stock LS ECU??
Old Aug 20, 2010 | 10:33 AM
xSteve_Ox's Avatar
Default Higher compression on Stock LS ECU??
I am building a high compression all motor LS and have a question. I am using the stock cams to break the motor in (and give me time to save some money for the cams/cam gears/and tune lol) Question being, only mods to the motor are going to be PR3 pistons (around 10.8:1 compression), built head with Crower valve train, ported ect ect. I have a AEM wideband (not yet but soon) and a B&M FPR and gauge, can I run the motor to break it in with stock cams on the stock ECU with no problems? Just better flowing top end and higher compression is different from stock. After 2,500 miles or so when the motor is broken in I will be taking it to Charm City, getting Brian Crower Stage 2 cams and adj. gears and tuned on S100 purchased/installed by them by there reccomendation..
Old Aug 21, 2010 | 07:51 AM
mtber's Avatar
Default Re: Higher compression on Stock LS ECU??
Simple answer: Monitor your air fuel ratios on the wideband.
Old Aug 21, 2010 | 07:55 AM
crvtectim's Avatar
That ^
Old Aug 21, 2010 | 09:20 AM
xSteve_Ox's Avatar
Word, that's what I assumed. What would be target AFR's for this setup?? Sorry I'm a noob at tuning but wanting to learn about it
Old Aug 21, 2010 | 09:27 AM
crvtectim's Avatar
I'd say 12.0 to 13.0 under wide open throttle.
Old Aug 21, 2010 | 09:36 AM
mouab18c1's Avatar
Get your target to idle around 14.7 then go from there.
Old Aug 21, 2010 | 09:48 AM
xSteve_Ox's Avatar
What about WOT and partial what should those be around safely? I'm not trying to get optimum power right now I just want to break the motor in safely then I can put the cams in and get it dyno tuned.
Old Aug 21, 2010 | 12:28 PM
mtber's Avatar
Using pump gas (91-93):
All motor vehicles: 12.9-13.4:1 (Full Throttle)
Partial Throttle/Idle: 15.5:1 (Light Throttle) 14.7-13.6:1 (Partial to Mid Throttle)
nokturnal_munkeeboy
Jul 23, 2006 08:50 PM
unknown0001
Apr 24, 2006 08:00 AM
PhatBoy5015
Nov 29, 2005 05:13 AM
IGotVTECyo
Jul 7, 2005 06:41 PM
jade butterfly
Mar 28, 2005 10:59 AM
