Will a p72 work
Old Oct 24, 2010 | 09:16 PM
b16bri's Avatar
Default Will a p72 work
I'm looking for a Stock ecu to use when i go for emissions It's a obd2 civic with a b16a swaped in it. I plan on putting the stock map sensor and sock injectors in and run a stock ecu to hopfully pass emissions Will a p72 work I know it's a b series but not a b16
Old Oct 24, 2010 | 10:30 PM
mouab18c1's Avatar
Default Re: Will a p72 work
p72 is a GSR ecu. Why not just get a stock b16 ecu? Makes more sense
Old Oct 25, 2010 | 07:41 AM
b16bri's Avatar
Unless i'm wrong the only obd2 b16 ecu is the 99 civic si which is obd2b my car is a obd2a. will this work with a conversion harness
Old Oct 25, 2010 | 09:21 AM
mouab18c1's Avatar
What ecu are you currently running? And yes the only obd2 b16 ecu is the 99-00 Civic SI. A JDM b16 might do the trick
Old Oct 25, 2010 | 12:49 PM
b16bri's Avatar
It's a jdm p30 but when it comes times for emissions i plan on converting the injectors and map sesnor back to stock and looking for some OBD2 ecu to run the engine which out throwing a cel and still allowing me to use the diaganostic port under the dash
Old Oct 25, 2010 | 02:21 PM
mouab18c1's Avatar
You're throwing a CEL with the JDM p30?
Old Oct 25, 2010 | 07:41 PM
b16bri's Avatar
No but from what i understand i may be wrong but i herd jdm ecu wont read our scanners here in the USA so when they wentr to plug in it wont work
Old Oct 25, 2010 | 08:03 PM
mouab18c1's Avatar
Im not sure about that either. My buddy has a 97 EK and he uses a jdm p30 ecu for emissions. One of my other buddies with a 92 Civic running an obd2 GSR also uses the jdm p30 for emissions. I understand that obd1 cars dont need the scanner, but with the JDM p30 it makes his car run lean but also passes emissions.
ricb20vtec22
Jan 3, 2014 06:48 PM
b16bri
Jun 30, 2010 08:10 PM
egmadness
Nov 9, 2005 12:01 PM
totaled
Aug 28, 2003 06:01 PM
743power
Aug 9, 2002 03:22 PM
