Microtech Lt-10
Old Aug 24, 2010 | 08:27 AM
FEDONV8's Avatar
Default Microtech Lt-10
I came up on a engine management. That i think is a little bit bizzare for my use. I have a Microtech Lt-10 ecu that has more feature that i heard then s300. Anyway i wanted to know if u guys can share a little bit of knowledge with what i have. And what is it compabilities.
Old Aug 25, 2010 | 07:54 AM
FEDONV8's Avatar
Default Re: Microtech Lt-10
bump
Old Aug 26, 2010 | 09:10 AM
2xraeted's Avatar
I got my car tuned with the LT-10s. It is a reall good unit but I can't compared it with others. Micro-tech does not enable you to use boost by gear.
Old Aug 26, 2010 | 07:34 PM
mtber's Avatar
Good luck finding a tuner that actually knows microtech inside and out in your area.
Sell the system & get something like AEM, Hondata, Neptune, Ectune. You will have much better luck finding a tuner for these systems.
Old Aug 27, 2010 | 09:24 AM
FEDONV8's Avatar
thanks for the info guys I really want to get rid of it the only place that can tune will be cft central florida turbos
Old Aug 27, 2010 | 11:12 AM
Abraham-ATS's Avatar
i use microtech in a lot of race cars specially rotarys and the reason its bc its simple but on a street car i dont recomend it and even a crome has more options the a microtech so get you self a s300 or a neptune and thats it...
Old Aug 28, 2010 | 09:09 PM
FEDONV8's Avatar
so what can i get for this unit if i have the complete harness just curious it is functional. And i will trade for it.
Old Aug 28, 2010 | 09:45 PM
arc_55's Avatar
The microtech is not a good computer to be looking at in the honda community considering all the better options for less money. The microtech lacks certain features and is a little rough on the edges. It seems to be popular in the rotory world and i have tuned an rx7 on microtech. It works but i am definatly not a fan of it espcially with the options you have.
Old Aug 28, 2010 | 10:09 PM
FEDONV8's Avatar
actually it has more feature then any other management and it came off a civic that ran well. Not asking for money just want to trade because the unit retail for 1100 but by it been used i think money will not be fair to take for someone when i cant get what i want for it so i think tried will be a option for this. but i have it for trade in the market place.
ECU
Flying Lead Wiring Loom (labeled)
Vacuum Hose
Fuel Pump Relay
Fuse Holder
Technical Manual / Booklet
General:
Weight 500gm
Extruded Aluminum case
1 Year Warranty
32 Bit Motorola Processor
Surface Mount technology board
Supports up to 8cyl and 2 rotor engines
Max readable RPM 15950
Max readable boost with standard map sensor :- 25psi
(30psi & 45psi versions avail as an option)
Fuel Delivery:
4 Injector Drivers capable of 4 amp peak hold.
True sequential operation on 4 cylinder and rotary
applications
Run up to 4 high impedance injectors per driver
Tuneable in MAP or TPS mode or combination of both.
RPM tuning range currently every 500rpm to 9000rpm
(12000rpm software option available)
Fuel Delivery Cont:
Auxiliary Input correction +-99%
Coolant temp correction
Air temp correction
Accelerator pump amount, sensitivity and Time
compensation
Cranking enrichment correction
After start enrichment correction
Cold Start accelerator pump correction
Hard cut RPM limiter
Soft cut RPM Limiter
Over boost Limiter
Sequential, Group fire and Staged/Group fire modes
Ignition:
4 Ignition drivers
Ignition setup preconfigured for engine type.
Configurable for 1-8 cyl engines using an external igniter
Configurable for twin distributors and 2 rotor engines
16 Ignition RPM sites (upgradeable to user definable
number. Software update will be available mid 2006)
16 Map corrections (upgradeable to user definable number. Software
upgrade will be available mid 2006)
16 water temp correction points
16 air temp correction points
Ignition advance/retard on accelerator pump
Ignition advance/retard on aux input trigger
Ignition Trim overall +-45deg
Ignition TDC reference adjustment on some applications
Ignition timing split adjustable on rotary applications
Accuracy to .25 degree
Aux inputs and outputs:
Standard features include One 12V Aux input
One –ve switched Aux output triggered by RPM, Map, water
temp
Aux Input cont:
One PWM output to run idle stepper motor control
Aux input can be configured to run Anti-lag, Mixture trim,
Timing trim etc.
Diagnostics:
Red LED indicated Fault code triggered
Data Page indicates where fault lies
Operational errors:-. Over boost, RPM Limit, RPM Cut, MAX
Duty, Water temp, Voltage, Shift Light
Self Test Mode runs all injectors and ignition and cycles aux
outputs
Amber LED gives Visual of ignition input signal
Green LED gives visual of power on.
Programming/ Tuning:
Using Laptop adapter and software
Using Handset or DASH unit
Sensors:
Configured to suit application when ordered.
Data logging and map storage:
On board “ECU-Log” Holds 5 minutes of memory . User
definable switching on and off point.
Data Log to Memory (Laptop) 100 samples per second
Viewed Data Log displays average readings 10 times per
second
Data log viewable in text or Graph
Playback data log
Print data log
Laptop logging standard. ECU logging optional & must be requested
when ordering
Save data log to disc
4 Maps saveable to laptop adapter or handset
kte324
Mar 8, 2009 08:21 PM
fez_ex_96
Jul 24, 2007 07:48 AM
DubyaAye
Apr 18, 2004 08:04 PM
Anyotherone
Mar 25, 2003 11:18 AM
