Ecu dummy
Old Aug 11, 2010 | 07:48 AM
jonathanh's Avatar
Default Ecu dummy
I don't have alot of knowledge when it comes to ecu's . I have a stock y8 that I just installed a turbo on . What would be my best bet on getting ?
Old Aug 11, 2010 | 08:33 AM
mtber's Avatar
Default Re: Ecu dummy
You need the following:
1. Proper sized injectors. (440cc precision or rc)
2. Proper sized fuel pump (walbro 255)
3. Map sensor if you plan on running more then 11 psi.
4. Conversion harness to run an obd1 ecu if your car is not obd1
5. Chipped obd1 ecu using an engine management a local honda/acura tuner tunes (neptune, ectune, hondata, crome etc)
Read http://www.phearable.net/tech/efibeginnerguide.html for more information
Old Aug 11, 2010 | 12:29 PM
jonathanh's Avatar
I have 440 injectors and a fuel pump and I only plan on running 7 or 8 psi for Now .
B16-CRX
Dec 22, 2010 08:26 AM
blasterman87
Sep 26, 2009 04:29 PM
90Rexx
Mar 25, 2008 06:16 PM
b18sihatch
Sep 12, 2006 09:09 AM
wsiracerz
May 25, 2004 08:41 PM
