Zeitronix Data Logger
Old Oct 10, 2010 | 07:46 AM
Acidcrakker's Avatar
Default Zeitronix Data Logger
Has anyone else had issues with this program?
I have it installed and it seems to be very sensitive.
Im running wiring, that I did my self, and it seems to be giving off false readings. It's probally because I wired the car up myself, but all has worked fine so far.
First issue I had was with the RPM signal. It was reading like 20k rpms at wot in 5k.
Now I got that fixed with a protometer. Now the issue is that my MAP sensor, A/F sensor are spiking. The MAP sensor seems to spike at WOT to close throttle, and there is a temp spike in the A/F ratio. Which goes to 14.9 or something like that.
Maybe the MAP sensor is bad? What are my options here, I contact the Zeitronix and well they have good support it just takes them forever to give it to you.
Old Oct 10, 2010 | 12:05 PM
shortyz21's Avatar
Default Re: Zeitronix Data Logger
nope, hooked mine up to the right wires first time worked perfectly
Veggie Man
Sep 25, 2012 02:49 PM
skata89
Dec 31, 2007 12:59 PM
Boosted Chemist
Jun 15, 2005 02:30 PM
