JDM ITR ECU help
Old Oct 7, 2010 | 05:02 PM
'00_GSR/R's Avatar
Default JDM ITR ECU help
I have a '98 JDM ITR ECU that came with my ITR swap (came from same caR), and I would like to put it into my '00 GSR (I know I need jumper). What Im really trying to find out is what sensors the JDM ECU uses? Most importantly what O2 sensors? Im planning on going with a new header, and test pipe. I think it only uses the sensor on the header and not the one on the cat, but not sure....? Any other knowlege about the JDM ITR ECU is welcomed as well.
Thanks
Old Oct 7, 2010 | 06:35 PM
'00_GSR/R's Avatar
Default Re: JDM ITR ECU help
Is there an imobilizer on a 98 spec JDM ITR ecu?
Thanks
Old Oct 7, 2010 | 09:11 PM
mtber's Avatar
There is no immobilizer in the 98 jdm ecu.
Concerning the o2 sensors, yes it uses them both to my knowledge.
If it was me, I wouldn't spend the money on an obd2a to ob2b jumper harness. I would use an obd2b to obd1 ecu jumper & chipped obd1 vtec ecu.
Old Oct 10, 2010 | 09:41 PM
Relic1's Avatar
P73-013 (98 JDM ITR ECU)
no immobilizer
does not use the secondary O2
will fail OBD2 emissions testing (all JDM ECUs do)
I have/use one, what do you want to know?
Old Nov 19, 2010 | 07:54 PM
J tech's Avatar
I just picked up a 98 jdm itr ecu, can i run straight plug and play to my 98 gsr or do i need additional equipment?
wmertz187
Mar 22, 2006 04:56 PM
95h22teg
Jun 22, 2005 03:20 PM
JDM TypeR 307
Mar 22, 2004 12:23 PM
96BlackHB
Oct 13, 2002 07:11 AM
