ECU Bare Essentials
Old Oct 17, 2010 | 05:48 PM
braddc's Avatar
Default ECU Bare Essentials
Is it possible to tune a P28 so that it will only have enough functionality to crank and run without any sort of safety or emission checks? I have a 96 Civic that has been converted to OBD1 with a Y8 VTEC Head and an d16 bottom end. It is in a dirt track stock car, so street-legal is not an issue. The problem I am having is that it will intermittently cut off while racing and sometimes even while idling. Very random. Everything on the car has been changed - all sensors, fuel pump, plugs, engine - but it still cuts off randomly.
Any ideas?
Old Oct 17, 2010 | 06:03 PM
mtber's Avatar
Default Re: ECU Bare Essentials
"cutting off randomly" Isn't caused by a "emissions check error"
Your problem is related to a wiring issue or ignition component problem etc.
Old Oct 17, 2010 | 06:05 PM
braddc's Avatar
What are you referring to when you say "ignition component problem"?
Thanks.
Old Oct 17, 2010 | 06:08 PM
mtber's Avatar
Thanks.
Ignition control module or coil issues.
You need to determine if the vehicle is loosing spark or fuel or both when you have this random "cut out". Then you need to proceed from there.
Old Oct 18, 2010 | 06:19 AM
braddc's Avatar
New fuel pump and filter. What else, other than the main relay, plays a part in the fuel side of the air / fuel mixture?
Old Oct 18, 2010 | 07:19 AM
rick_rabies's Avatar
I'm not Rick!
injectors. are all the clips on snug.
any wires shorting out?
main relay in good condition?
try another one from the junk yard.
main relays can be goofy and annoying
Old Oct 18, 2010 | 01:22 PM
braddc's Avatar
injectors / wires good, tried several different relays - took apart and examined solder joints and all OK.
thundernoodle
May 2, 2011 06:34 PM
rquint07x
Engine Management and Tuning
Feb 8, 2011 04:09 PM
noluckracing
Sep 14, 2009 04:38 PM
honda305
17
Feb 26, 2009 08:21 PM
