how accurate are s300 base maps?
Old Aug 29, 2010 | 10:43 PM
bakomack's Avatar
Default how accurate are s300 base maps?
local tuner calls me off craigslist and wants to buy my s300. says hell give me cash plus a virgin p72. when I say no he gets mad and says that im better off running a factory p72 rather than a p72 base map on hondata. is he blowing smoke up my *** or what?
Old Aug 30, 2010 | 03:14 AM
GhostAccord's Avatar
Default Re: how accurate are s300 base maps?
IMO, If you have a stock B18 engine then a stock P72 would be your better choice vs a base map. Now if you actually had the S300 tuned that's a different story. For a stock engine getting it tuned is a bit much.
Old Aug 30, 2010 | 02:17 PM
bakomack's Avatar
I have a jdm b16a with pct pistons and a fully built head with stage 3 cams.
we were tamling through text and he was under the impression I still had my 98 jdm type r with stage 3 cams.
but anyways are the base maps on s300 identical to factory ecu's? if not then why say they are the actual base maps.
if their not accurate then I could possible load a supercharged b18c5 base map and it would run my motor as well as a p75 base map in smanager right?
Old Aug 30, 2010 | 05:46 PM
mtber's Avatar
The "stock p72" basemap is the same thing as a "stock p72 ecu".
Old Aug 30, 2010 | 05:55 PM
Are they identical, maybe. Will they run a stock engine, yes. Will it be optimal without a tune, probably not. They are called base maps because that's exactly what they are. A base in which to start tuning from. If you have stage 3 cams and higher compression pistons an S300 base map is not going to run your car optimally without tuning.
Is this a serious question?
I never said they weren't accurate. I said that they wouldn't run a stock engine as well as a stock ECU without tuning.
I think it's time to hit the books!
Cheers
Old Aug 30, 2010 | 10:32 PM
bakomack's Avatar
Cheers
no it was total sarcasam but as the guy said above if its a base map to start tuning from cant I just chip a p72?
I just wanted to know is the base maps were the same as the factory ecu's. if they are then thank you thats what I needed to know
Old Aug 30, 2010 | 10:49 PM
hood ride eg's Avatar
yeah you can tune a p72 if its chipped for ex like on Chrome.
but Depending on the build id say you can have a solid answer , hondata is another great upgrade but again like they said previously a TUNE is going to be effective with your setup
Old Aug 31, 2010 | 07:44 PM
bakomack's Avatar
I know I need a tune. all I want to know is are the base maps in smanager IDENTICAL to a factory ecu. yes or no and how do I find out if they are
Old Sep 1, 2010 | 06:07 AM
Boost>NA's Avatar
mtber answered your question up there ^^^
a stock p72 has a stock p72 basemap on it so if the stock p72 basemap is downloaded onto the ecu with the s300 in it then that ecu will act as a stock p72(reffering to fuel maps, sensors can be disabled by the s300 if needed).....somebody correct me if i'm wrong
092eg6
Engine Management and Tuning
10
Mar 19, 2017 08:28 PM
kulo
Feb 25, 2009 01:54 PM
fatpride111
Dec 15, 2008 05:47 PM
Rocket
72
Nov 19, 2008 06:54 PM
paulITR
Dec 25, 2004 09:43 AM
