ecu help
Old Oct 28, 2010 | 07:36 PM
prelude2121's Avatar
Default ecu help
just woundering if you need obd1 or 2 to tune a car because my car is obd0 and i cant seem to find anny tuneing programs or chips like neptune for obd0
Old Oct 28, 2010 | 07:44 PM
bb6kid22's Avatar
Default Re: ecu help
obd1
Old Oct 28, 2010 | 08:29 PM
mtber's Avatar
Convert to obd1 using an obd0 to obd1 ecu jumper harness & distributor jumper if you don't feel like messing with your distributor wiring. You will also need an obd1 distributor & obd1 ecu setup for your engine setup with the ems of your choice.
Old Oct 29, 2010 | 02:39 PM
i also read that obd0 has a 1 wire o2 sensor but myn is 4 but my motor is out of a 89teg is there anny other ways to tell if its obd1
Old Oct 29, 2010 | 04:18 PM
ben_deez's Avatar
look at the ecu... obd 1 will have 3 connectors..., obd0 has 2
also "BRE" is an editing program for obd0... check pgmfi.org
Old Oct 29, 2010 | 04:23 PM
kk thanks i also looked up and my motor is obd1 cuz it sais it will be stamped with p29on the intake and myn is and alsot map sensor is on the tb
ricardo13d
11
Dec 8, 2011 06:55 PM
bayron
May 14, 2009 05:39 PM
darrenVT
Engine Management and Tuning
18
Sep 30, 2008 09:18 AM
91dxcrx
Jan 22, 2006 05:46 PM
tRex99
Sep 5, 2004 05:28 PM
