Datalogging with crome
Old Oct 10, 2010 | 09:49 AM
boogienights's Avatar
Default Datalogging with crome
Is it possible to datalog with the free version of crome?
I have the xtreme hulog, but the settings in crome doesnt have a tab for tuner comm
is there something im doing wrong?
Old Oct 10, 2010 | 10:29 AM
mouab18c1's Avatar
Default Re: Datalogging with crome
No, you need CromePro
Old Oct 10, 2010 | 10:36 AM
I guess freelog is, my only option?
Old Oct 10, 2010 | 03:16 PM
mouab18c1's Avatar
I honestly dont think freelog even works anymore. Cromepro is only $150 or so. Search for actual cost.
Old Oct 12, 2010 | 07:39 AM
mtber's Avatar
Spend your money on eCtune, hondata or neptune instead. You will be much happier.
Old Oct 18, 2010 | 12:38 PM
ZAN_TUNING's Avatar
Why you need datalogging? Just put the thing on a dyno and make adjustments where needed. It's not hard.
Old Oct 18, 2010 | 12:49 PM
mtber's Avatar
There are several reasons why you would want to be able to view live data from the ecu.
1. Make sure the ect & iat values are correct.
2. Make sure your map sensor is reading the correct values.
3. Be able to cell trace for people who can't "guess".
4. Make sure tps is reading properly etc....
The list goes on.
Old Oct 18, 2010 | 01:24 PM
ZAN_TUNING's Avatar
I think it's a nice little addition, but definitely not neccessary to get a great tune. If he isn't going to shell out 150 for legal Crome then it's not going to hold him back is my main point. I still never use datalogging lol.. only on PFC occassionally
Old Oct 18, 2010 | 04:47 PM
mtber's Avatar
Maybe we should all stop using romulators too?
We should also start using UV erase chips again too!
lol
Old Oct 18, 2010 | 05:09 PM
mouab18c1's Avatar
Guessing works, but whats the point of technology? To make our lives easier in some ways. LOL You wont want to guess anymore once you start Datalogging.
Old Oct 18, 2010 | 06:35 PM
ZAN_TUNING's Avatar
Guessing??? It's not guessing. If you are on a dyno then everything is plotted right there in front of you. Rpm, torque, AFR, and Load. What more do you need? Ohhhh you want to know the EXACT cell so you don't mess up. That's sad if you "need" alllllll that little info to do a proper tune. Even when I tune blow-through carbs it's not guessing.. it's knowing the system. I'm sorry that some people are spoiled with "technology" and are in-capable of tuning without every single little piece handed to them.
The thing is I didn't jump in here to knock on datalogging... just that it isn't NECESSARY for this guy to tune his car. All he needs is a dyno and some time and he's good to go!!! LOL You guys are telling him that he's FUBAR because he has free crome and it's just not true!!!
Old Oct 18, 2010 | 07:30 PM
mouab18c1's Avatar
I never said anything about free Crome being bad, used it before and never had an issue. Not many people have dyno's to use FYI. Datalogging is good for street tuning.
Old Oct 18, 2010 | 07:39 PM
ZAN_TUNING's Avatar
I apologize I just got a little defensive which is lame I know. Datalogging is a great feature and can make things easier no doubt. It's just a personal thing.. I started tuning years ago on turbo carb setups and from there transitioning in to stand alones and such never even thought about using data logging. Street or dyno :/
There's gotta be a dyno around no? That would suuuuuuck. If not, with patience and hopefully some common sense (tuning wise) there shouldn't be an issue. Using 4th gear and going little by little it's still not an issue in my mind. Have someone drive while he watches gauges with laptop in passenger seat
Old Oct 18, 2010 | 07:43 PM
mouab18c1's Avatar
Dataloggin allows you to record and then make your changes if you dont have someone to sit in the car with you. Its a nice feature and helps keep the drivers eyes on the road.
Old Oct 18, 2010 | 07:47 PM
ZAN_TUNING's Avatar
Yes it does... but what happens when you've already detonated? Might be too late I just think it can allow too much comfort in certain situations for people less experienced.
If a person doesn't have enough friends to where they can not get a driver for a little bit.. well they probably wouldn't have the car in the first place :D
Old Oct 23, 2010 | 07:24 PM
ghettojuice87's Avatar
can the demon work with crome pro?
champLSinteg
May 24, 2008 10:36 AM
Twistedframe
Aug 20, 2007 05:11 PM
Twistedframe
Aug 20, 2007 05:08 PM
flangemastermike
Dec 26, 2006 08:45 AM
HavokB18
May 5, 2005 08:45 PM
