Help: Super Rich/Idle issue
Old Aug 21, 2010 | 10:49 AM
elliott_219's Avatar
Icon2 Help: Super Rich/Idle issue
Tuesday night driving home I noticed my car wasn't running properly.
Del Sol
B16a
1. Idle is down to 500 RPM. The car is barely staying running (sputters) and puffs black smoke. Stalls when first started if I raise the rpm at all.
2. RICH. Smell of gas is crazy.
3. Black spark plugs
So Weds. afternoon, i took off the IACV and cleaned the **** out of it (been meaning to do this for a while). Didn't help.
Thurs. I pulled the plugs. The plugs were still farely good shape, but they were BLACK!!!!. I replaced them with brand new plugs and ran the car for 2 mins. Same things 500rpm idle and rich. Pulled the plugs and they were just as black as the old ones.
Today i replaced my aftermarket fuel pressure regulator with a new OEM one. No change. Also checked all my vacuum lines twice, all connected and no sign of any holes.
I do have chipped ECU but I have had this since i bought the car. There is also a small exhaust leak.
So... What could be the problem? Timing (if it can throw itself off)?
Old Aug 21, 2010 | 12:28 PM
mtber's Avatar
Default Re: Help: Super Rich/Idle issue
Is your check engine light on?
If so, check your codes...
Old Aug 21, 2010 | 12:31 PM
no check engine light.
Ends up. The Map sensor that replaced 2 weeks ago broke. The nipple broke off in the hose.
SuM Honda
Jan 1, 2010 07:29 PM
Nos4R2
Apr 20, 2007 07:22 PM
bennyhonda7
Jun 21, 2005 12:49 PM
Armed Ferret
Jun 28, 2004 10:00 AM
shahram72
Dec 19, 2002 10:49 AM
