P28 Issue, Repairable?
Old Aug 15, 2010 | 01:14 PM
Jimster480's Avatar
Default P28 Issue, Repairable?
Ok so I got tuned yesterday and I made 300WHP on the dyno @ 19PSI. After the tuner burned the chip and we put it in my ECU and went for a drive. It wasn't even hitting VTEC and it would hit the 2step for no reason. it seems to have an issue with the VSS input, although the speedo itself works perfectly fine, and the car runs fine with the tuner's ECU so I know its the ECU. I am going to go pick up another P28 today but I was wondering if there is any way to fix the ECU? If anyone knows what chip controls/receives signal from the VSS since my friends dad is very good with circuit's and can repair circuit boards I would just need to know what to replace. Thanks in Advance.
Old Aug 15, 2010 | 09:49 PM
mouab18c1's Avatar
Default Re: P28 Issue, Repairable?
Xenocron.com
Old Aug 15, 2010 | 11:01 PM
Jimster480's Avatar
And that helps me how? Like I don't know about that site....
Old Aug 16, 2010 | 08:35 AM
mouab18c1's Avatar
Send it to them and they'll fix it. If not then goodluck. My ecu was throwing a code 4 in everysingle car. Paid $25 for the service and $20 for shipping. Works good again.
Old Aug 16, 2010 | 08:52 AM
Jimster480's Avatar
damn only $45 to fix the ECU? Thats damn good considering a new one is $120+
Old Aug 16, 2010 | 09:34 AM
mouab18c1's Avatar
Thats what I figured. Give em a call or something.
Old Aug 16, 2010 | 03:57 PM
xenocron's Avatar
This is why I only tune with the customer's ECU and have been for the last few years...unless the circumstances make it so I have to use one of my tuner ECUs. I have seen differences in customers voltages in the ECU, injector drivers can get "old" and boards with capacitors that are failing can act completely different with a chip versus a good or even just different ECU.
If your ECU is having a VSS input issue (never seen one of those personally, so I doubt I could fix it) you can disable the VTEC Speed Check, and disable 2 step in the meantime to get around that issue. Chances are likely too that if it is having an issue like this, you might have other internal issues not readily apparent but there nonetheless.
As far as figuring out which components are being effected, have your dad's friend trace the circuit from the ECU pin input for the VSS (B10) and trace it back through the board.
Old Aug 30, 2010 | 01:48 PM
7rrivera7's Avatar
I'll fix it for $55 shipped...
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEUSX:IT
Old Aug 30, 2010 | 02:23 PM
Jimster480's Avatar
alright, ill send it to you as soon as i have the $, which should be in a week or less.
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
ICEMAN707
12
Jul 2, 2006 03:45 PM
SOHC_MShue
Nov 11, 2004 11:52 AM
Slow Egg
Mar 20, 2003 09:07 PM
