basic ecu question... easy
Old Aug 10, 2010 | 04:03 PM
93h2beg's Avatar
Default basic ecu question... easy
how do i know if the ecu im looking at is usdm or jdm? its for a h22 p13... if that matters.
Old Aug 10, 2010 | 07:32 PM
SDHonda153's Avatar
Default Re: basic ecu question... easy
JDM ECU's are usually smaller and look more like a square, whereas a USDM ECU's are longer and more rectangular.
Old Aug 10, 2010 | 08:13 PM
GhostAccord's Avatar
x2
OBD1 USDM is a rectangle and the JDM is a square.
Another way to tell is via the bar code on the side.
The bar-code will show the ECU part number, if the last three digest start with a J or a 9 it is JDM. Example 37820-P13-J01 or 37820-P13-900.
Old Aug 14, 2010 | 10:01 AM
93h2beg's Avatar
ok thanks guys, i had heard they were different shaped, im really just looking for a way to get by a state ref, if he looked at the jdm ecu and knew it was jdm, it would not pass, so.... guess i ll have to actually find a usdm p13
Old Aug 14, 2010 | 10:11 AM
HRTuning's Avatar
The USDM and JDM P13 are the same size. You can look at the numbers on the side or open it up and identify the ROM number or specific components to tell if it's JDM or USDM.
To pass the state ref you will need a USDM P13. They will not pass a JDM P13.
HELLAnorcal
Nov 2, 2006 10:16 AM
Lauj87
Oct 16, 2005 10:27 AM
BLK99VTECR
Jul 2, 2004 09:34 PM
ptsiu
Nov 30, 2003 11:28 PM
