2001 s2k floods cold
Old Oct 4, 2010 | 10:13 AM
dthondas2k's Avatar
Default 2001 s2k floods cold
Hi, This is my first post. I have a 2001 s2k that sometimes floods cold. Will run very rough for about 20 seconds then clear out or not start at all. When it won't start i have to remove and dry plugs. All sensors in spec, missfire codes present. I don't know if too much fuel is introduced or timing issue. Problem has become more frequent since turbo install ( larger injectors? ) Pulling my hair out. Please help
Old Oct 4, 2010 | 10:46 AM
mouab18c1's Avatar
Default Re: 2001 s2k floods cold
Simple you need a tune.
Old Oct 4, 2010 | 11:58 AM
dthondas2k's Avatar
Thanks for the reply. By a "Tune" do you mean a fuel mapping of the ecm?
Old Oct 4, 2010 | 02:10 PM
Spunkster's Avatar
What are you using to adjust the ECU after installing larger injectors? Without proper engine management you will have a blown motor in a very short time.
http://www.hondata.com/s2000kpro.html
Old Oct 4, 2010 | 02:47 PM
dthondas2k's Avatar
I am using a Greddy e-manage blue system.
Old Oct 5, 2010 | 07:39 AM
dthondas2k's Avatar
Ok, more info. This morning cranked for maybe 8 revolutions, no start. Pulled plugs and found coolant on three of them. Seems odd to have a head gasket leaking on three cylinders. Has anyone seen another source for coolant in the cylinder?
Old Oct 5, 2010 | 12:26 PM
em_at_kfi's Avatar
Ah, you have coolant on the plugs. I was presuming it was wet with gas from being too rich on cold starts, in which case you could "fix" through software/tuning. But coolant is an indication of an entirely different issue.
Old Oct 5, 2010 | 12:55 PM
dthondas2k's Avatar
Yup, thats what I thought at first. Previous times I pulled plugs was after extended cranking so all I saw was the gas. Looks like a head Gasket or worse. The only confusing thing is that there is coolant in more than one cylinder, and only a few drops.
Old Oct 5, 2010 | 01:49 PM
adamrich33's Avatar
could it possibly be condensation and not coolant? does it smoke/steam out the exhaust after it warms up when not cold out, or does the coolant levels drop without signs of a leak?
g2turbo
Engine Management and Tuning
Aug 20, 2013 05:16 AM
t0mmyt
Jun 6, 2013 10:16 AM
dragon_lowrider
Apr 4, 2010 03:41 PM
Swansen
May 2, 2009 10:44 AM
mecaneck77
Oct 27, 2007 07:52 AM
