P75 to P28
Old Jul 10, 2015 | 03:21 AM
LightningTeg's Avatar
Community Builder
Default P75 to P28
Hey guys I recently went LS VTEC and had a friend of mine solder the moates kit to convert my P75 to P28. When I set up the tune in eCtune, do I need to make sure the ecu selection is P28 at the first screen or does it not matter? (currently setup for P75)
Car runs pretty good on my old LS tune for low cam so far, so it would save me some time to just use it. I could copy the tables over to a fresh map otherwise.
Old Jul 14, 2015 | 04:34 AM
Community Builder
Default Re: P75 to P28
A little research (from crome at least) shows different codes being used for the different ecus, so one should use the code specific for their ecu. Started a fresh map on the "now P28" and everything works fine.
Old Jul 27, 2015 | 08:56 AM
johnie1199's Avatar
10 Year Member
Yes sir same thing when I changed from Neptune to hondata but i also bought a po6 ecu converted with my lsvtec. how you liking the new setup when I made the switch to the dark side it was vary noticeable to me but I did only have a 300hp ls when I did the lsvtec gained 60hp more now going for 800s lol been a while
Old Aug 8, 2015 | 06:32 PM
dansparkeyASE's Avatar
So is it possible when converting to go p72 or p28?
Lot of he say online and I did the moates 1980 board v tech kit. That's going to result in 272 clone being its a 1980 board. Witch only with the p 75 use this board
evosix
Engine Management and Tuning
Aug 26, 2016 04:37 AM
ls_bitik
Oct 22, 2007 08:52 PM
04falcon
Nov 29, 2004 05:34 PM
Vtec92Civic
Oct 3, 2004 02:58 PM
