overheating because not enough ignition timing?
Old Aug 2, 2015 | 05:49 PM
RACEPAK's Avatar
Default overheating because not enough ignition timing?
hey guys,
question for the tuners here,
ave you ever had a boosted engine overheat because it dosnt have enough ignition timing?
something around 4-8 degrees less then mbt?
thanks
Old Aug 3, 2015 | 04:11 PM
Muckman's Avatar
Moderator in Chief
Default Re: overheating because not enough ignition timing?
No. You have other issues. If that were true everyone would overheat as you start tuning from a safe conservative point and advance from there.
Old Aug 4, 2015 | 02:54 AM
blackeg's Avatar
i have seen egt go sky high due to extreme retarded timing on a few cars over the years. i would have to assume that with all that extra cylinder heat it could lead to higher coolant temp. 8 degrees less than mbt seems like a lot to me but then again its really only 6 degrees less since it seems common practice to pull back about 2 degrees once you find mbt...
Old Aug 4, 2015 | 06:35 AM
mtber's Avatar
Originally Posted by RACEPAK
hey guys,
thanks
No, look elsewhere.
Old Aug 4, 2015 | 06:46 AM
B20VtecVillain's Avatar
Originally Posted by mtber
No, look elsewhere.
Are you saying that because of the numbers he posted or just in general because you don't feel extreme retarded timing would cause increased ECT? I'm curious because I have seen the same as was said above, crazy high EGTs due to retarded timing and was also u see the assumption that such increased cyl temps could lead to increase in coolant temps, but if that isn't correct I would love to learn why so educate a brother! Lol
Old Aug 4, 2015 | 06:53 AM
mtber's Avatar
Numbers he posted.
Old Aug 4, 2015 | 09:30 AM
Rtype16's Avatar
I agree with mtber the numbers he is posting is not really something that would cause a car to overheat. Maybe at 8 degrees retarded at a prolonged time at wide open throttle however if its overheating at that I would still lean towards a poor cooling system itself and not the 8 degrees.
jdmb16ef8
10
May 4, 2008 04:47 AM
mortificationrock
Jul 10, 2007 04:26 PM
SOFLSOL
Sep 16, 2003 01:44 PM
Veil_Side_
Jan 6, 2002 12:30 AM
