Factory ECU REFLASH
Old Jun 19, 2015 | 09:12 AM
BIG T's Avatar
Default Factory ECU REFLASH
Does anyone know a dealer nationwide that will flash a stock rewritable ecu with a different tune than its factory tune. IE: CRV ----> TSX
Old Jun 20, 2015 | 01:36 PM
TheShodan's Avatar
Moderator
Default Re: Factory ECU REFLASH
No one in the Honda OEM world will have that. Only the aftermarket will support such an endeavor.
Old Jun 22, 2015 | 06:09 AM
BIG T's Avatar
got any recommendations of companies or shops that might do it?
Old Jun 22, 2015 | 09:23 AM
TheShodan's Avatar
Moderator
Any Aftermarket performance shop that deals with Hondata in your area.
You may need to go to Hondata's Dealer List and make some phone calls. But you would need to purchase Hondata equipment from them in order to do this. The Honda ECUs are not like those from other manufacturers that are able to be adjusted by way of Open Source or some programmable hand module.
Old Jun 23, 2015 | 03:31 PM
Spunkster's Avatar
This is not something that Hondata can do. Do not call them asking.
Old Jun 23, 2015 | 03:36 PM
TheShodan's Avatar
Moderator
Not to "flash" anything, no.. I'm skipping the notion of that being a possibility by ignoring it completely, and going with an aftermarket alternative, which is a Hondata solution.
Old Jun 23, 2015 | 04:05 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Why can't he call Hondata? Is their customer service really so bad that they can't field a simple question?
Old Jun 23, 2015 | 06:02 PM
TheShodan's Avatar
Moderator
Would that really surprise you?
Old Jun 23, 2015 | 09:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If the ECU that the OP intends to use is a DBW type and Hondata offers a FlashPro for this ECU application, couldn't a Hondata dealer with a Dealer FlashPro system program an alternate basemap in the ECU in question... or even create a custom tune specifically for the OP's engine combination ???
SovXietday
Jun 30, 2007 10:08 AM
SJdc5
Feb 17, 2006 11:46 AM
pYrostu Type S
Jan 13, 2003 11:08 PM
TurbodCX
Feb 15, 2002 10:09 AM
