f22b1 vtec base map for Hondata
Old Dec 26, 2014 | 09:51 PM
Treyschls's Avatar
Default f22b1 vtec base map for Hondata
Im searching for a base map to get my car started.
I haven't been able to find a map from Hondata.
Anyone know path I could take to start making my own
so I can get the car to a dyno?
Old Dec 27, 2014 | 06:21 AM
Turbokraft's Avatar
Default Re: f22b1 vtec base map for Hondata
Use an H22 base map(similar displacement), insert your injector and map data under parameters and you should be able to drive the car. If you still have a stock O2 sensor enable closed loop and drive easily until tuned.
irocdaparty85
Jul 25, 2005 09:23 AM
1.8T_EG
Feb 14, 2003 10:12 AM
