Back probing an ECU
Old Apr 5, 2015 | 01:33 PM
Treyschls's Avatar
Default Back probing an ECU
Can I back probe the ecu to check ECT & IAT sensor resistance?
Old Apr 5, 2015 | 02:48 PM
98vtec's Avatar
moderator emeritus
Default Re: Back probing an ECU
Why don't you just check it at the sensor like most people do?
Old Apr 5, 2015 | 04:12 PM
Treyschls's Avatar
Because its in a b**ch of a location
Old Apr 6, 2015 | 06:44 PM
VegasInvasion's Avatar
I'm Huge In Japan
If you're testing resistance to see if a sensor is bad, then no. It has to be done at the plug, because the wires add resistance, and more often than not the wires are the problem. But you can always remove the sensor and test it, since a thermistor doesn't need power for ohms readings. 99% sure your sensor is fine.
But really you should be measuring voltage anyway. Which ideally should be done through datalogging, but voltage at the ECU plugs is the most accurate analog reading. If voltage checks out, your ECU is bad. If it doesn't, it's probably a bad ground connection at the thermostat.
chevy383
Jan 1, 2014 02:39 PM
tgmueller
Apr 29, 2013 10:42 PM
luispequeno
Dec 13, 2010 09:16 AM
jaha-crx
Sep 24, 2008 09:37 AM
andyt
Feb 20, 2007 06:08 PM
