tunerview 2 with crome pro
Old Jul 25, 2015 | 04:22 PM
Hillbillyrex's Avatar
Default tunerview 2 with crome pro
ok so im at my whits end with this tunerview 2, for the life of me i can not get it to connect and read data from the cn2 port. im running the latest version of crome (1.6.13) have verified the cn2 is putting out the correct voltages for each pin. have done everything on hrtunings website list for help and still no connection. what could possibly be the problem here. kinda disappointed that i cant get it working.
Old Jul 25, 2015 | 05:07 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: tunerview 2 with crome pro
Screen shots of settings would help... Also, is this a new or used unit? If used, what are the cable pinouts on each end? How about which port on the TV are you using?
You didn't give much for details and that's what matters.
Old Jul 25, 2015 | 05:36 PM
The tv2 is brand new, im using the bottom port which is for direct connection to the ecu. Verified that the data cable was pinned correctly.
Old Jul 26, 2015 | 03:37 AM
WIKKEDV16's Avatar
Ttt!!!
Old Jul 27, 2015 | 03:21 AM
Ttt!
Old Jul 28, 2015 | 10:21 AM
Going up on a Tuesday
Old Jul 28, 2015 | 11:01 AM
DO IT ON ALL FOURS
I'll post this again. You haven't provided anything else to help you with.
Old Jul 28, 2015 | 01:51 PM
I'll post this again, I have done everything posted on hrtuning website in there help section, searched the interwebs for countless hours and still have nothing. Everything on the tv2 is setup correctly to use with crome. It simply will not connect. So from your information or what you have provided has not been of any help but aggravation because you don't comprehend I've done all there is to do. Need to word it any differently?
Old Jul 28, 2015 | 02:15 PM
HRTuning's Avatar
More than likely you're not running the Crome Datalogging Script 2.0 which the website mentions is required.
"*Crome support uses the common Datalogging script 2.0"
Old Jul 28, 2015 | 02:30 PM
I have tried loading the link that is provided in your " help" section and it always fails to load whether I'm on my phone or laptop.
Old Jul 28, 2015 | 02:36 PM
bluenc-87's Avatar
I just bought crome, but is using Hulog. If its the same, when you istalled tunerview check which COM port number your laptop have assigned it to your laptop under device manager. Click/Look for your assigned COM in laptop and remember the "bit per second" number. Then look for Advanced tab at the bottom and go into it and change "Lantecy to 1 as it would normally be 16.
Open crome and go File/Settings/Tuner Comm. Set your "baud" to the Laptops "bit per second" number and choose the correct COM port number you was assigned to. Cilck ok (Tip: Dont click Test Connection as it dont work).
You should be ready to load your map to device and start tuning.
This may help..... http://static.moates.net/zips/crome/...ME%20v1.06.pdf
Old Jul 28, 2015 | 02:49 PM
Appears pgmfi website has been down since 6-2-15, maybe that has something to do with getting the correct data logging script needed.
Old Jul 28, 2015 | 03:39 PM
DO IT ON ALL FOURS
Yup, no clue what I am doing since I set all three of mine up fine (as well as a couple dozen others) with my CROME Dealer and HONDATA. I really have to stop making all these threads asking for help. I do apologize for being a hindrance to the productivity of this thread. Good luck.
Old Jul 29, 2015 | 04:54 AM
HRTuning's Avatar
I don't know if it's built into Crome or not, or where you can get it otherwise, but that's what is needed to use the display at this time. The link was to a forum discussion about the 2.0 script, not the script itself.
Perhaps if you apologize to OneBadTurboCRV he'll be willing to help you out with that.
Old Jul 30, 2015 | 04:55 PM
VegasInvasion's Avatar
I'm Huge In Japan
Start with a fresh P30 USDM rom, install Crome's existing Quick Datalogger 2 (QD2) protocol plugin. I've done it on 6 different ecus with 6 different tunerviews just like that. As long as you chipped the ecu correctly and connect to the right port on the tunerview, it'll work.
By the way, IT DOES NOT WORK WITH THE GOLD ROM.
Joreus
11
Jul 3, 2011 10:35 PM
thatcivic96
Engine Management and Tuning
Aug 11, 2010 10:01 PM
greddy13
May 3, 2006 06:41 PM
