eBay USDM ecu was jdm
Old Dec 7, 2014 | 01:42 PM
Mendoza33's Avatar
Default eBay USDM ecu was jdm
Ha I knew it but can anyone confirm this. I bought a what suppose to be a usdm ecu on eBay that turned out to be a jdm ecu I think. Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=131360007121&alt=web
Old Dec 7, 2014 | 06:10 PM
Thor294's Avatar
Default Re: eBay USDM ecu was jdm
023 is jdm 2000-2001. i have a 003 which is 96-97. 013 is 98-99. not all P73s are JDM. For instance, P73-A03 is USDM ITR 96-97
Old Dec 8, 2014 | 05:56 AM
Mendoza33's Avatar
Yeah I remember that all jdm Integra Type R ecu are OBDIIa while usdm Integra Type R ecu are OBDIIb, I'm just not sure if all usdm ecu are OBDIIb
Old Dec 18, 2014 | 05:53 AM
HAMOTORSPORTS's Avatar
Other than not being able to read codes via the OBD2 scantool and the JDM ECU not needing a VTEC oil pressure switch, the ECU's are very similar. The fuel and timing maps are not very different between the two.
What vehicle/engine are you using this on?
Old Dec 22, 2014 | 03:31 AM
Mendoza33's Avatar
I got a 96 spec itr engine that I am wanting to pass emissions here in Texas.
Old Dec 22, 2014 | 04:08 AM
LTCxD2B's Avatar
Ur gonna need that usdm so the obd port works to pass emissions
Old Dec 29, 2014 | 03:27 AM
Mendoza33's Avatar
Is there any other ecu that will work besides the usdm itr ecu? I'm only going to drive the car to a local gas station that has an inspection check which is about a mile away.
Old Dec 30, 2014 | 01:11 PM
LTCxD2B's Avatar
The b16 usdm Ecu is the closet ignition wise but will run super lean an LS ecu will also work but may drive like crap lol
hotroddb8r
Jan 4, 2008 06:34 PM
Lauj87
Oct 16, 2005 10:27 AM
ptsiu
Nov 30, 2003 11:28 PM
