Crome unknown problems.pls help!!
Old Jan 25, 2015 | 06:09 AM
AK47GR's Avatar
Default Crome unknown problems.pls help!!
Hi to everyone!I buy honda ecu tuning kit from moates.I try to read the chip from the tuner who program my car and now the chip is empty.I try to make new one and all go succesfull but my check engine never turn off and car does not start.My tune was:b16a2 forced,omni4bar map,precision 780cc 12om,stock throtle and intake,t3t4 turbo.HERE IS WHAT I DO ON FREE CROMEpen crome,select p30g edm civic b16a2(209),remove checksum,quick datalogger and rtp,p30 option bite hack,install rev tools,add extra features,advance boost tools,select xenocron 4bar,14 boost columns,add fuel tools,multiplier calculator new injector 800cc,advanced table-injector battery offset-select precision turbo 525cc 12om,and disable all sensors.CAN I DO SOMETHING ELSE?pls help me because i talk to moates and dont know.....
Old Jan 25, 2015 | 11:23 AM
GhostAccord's Avatar
Default Re: Crome unknown problems.pls help!!
What are you using to read and burn/buffer the rom file to the chip?
Old Jan 25, 2015 | 01:40 PM
VegasInvasion's Avatar
I'm Huge In Japan
First off I have to assume it's not chipped correctly, because that's the most common problem. Second I have to assume the chip may have been installed backwards, is not seated correctly, or is defective. Third idea would be to check the engine codes.
If it's code 0, it's either a wiring problem or most likely a bad rom. Use the JDM P30 base, I don't think the EDM base works at all.
Don't add the option byte hack. Don't add rev tools, you don't even need that.
Don't add extra features until you've set up boost tools, burned a chip and know it works.
Don't disable ANY sensors unless you actually don't have one of them, and you better have good reason for not having any of them other than VTP and O2.
Go to PGMFI.org and search before you post, literally every question or problem you will have with Crome has already been answered, most of it by me, and any new threads containing old problems will be deleted.
Old Jun 1, 2015 | 07:43 AM
AK47GR's Avatar
crome doesn't have ghost on maps?
x4code
Engine Management and Tuning
Jun 18, 2015 07:23 PM
mattsnooz
May 29, 2008 12:18 PM
Jman8108
May 4, 2008 07:22 PM
b18bcrxhf
Dec 9, 2006 07:25 PM
JDMlyfestyle
Jul 17, 2005 11:11 PM
