Constant code 41 after studdering issue?
Old Mar 19, 2015 | 10:13 AM
ShinsenTuner's Avatar
No Jodas
Default Constant code 41 after studdering issue?
Preface: car is a 1996 Civic DX hatchback with an H22A4 swap running Hondata S300 V1 in a P28 ecu with a Phearable.net basemap and running with closed loop disabled (no o2 sensor, open loop)
The last time I drove the car it gave me issues with bogging while coasting and initial acceleration (less than 30% throttle position)... i had this problem when I first got the car, replaced the ecu with the S300 and it went away
Now it has a constant code 41 (o2 sensor) code even if I have it running open loop... how can this be? Is something wrong with the board? I opened it up and didn't see any indication of burnt chips or anything. Any help is appreciated.
Old Mar 19, 2015 | 11:07 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Constant code 41 after studdering issue?
Code 1 is for O2 sensor signal. Code 41 is for O2 sensor heater. Disable the heater as well... selecting Open Loop is only one part of the equation.
Old Mar 19, 2015 | 05:38 PM
VegasInvasion's Avatar
I'm Huge In Japan
H22 basemaps run like garbage. I've tuned hundreds of them, and the basemaps never run right. You NEED to fully tune it.
I digress, there's a possibility either your S300 is bad, the ECU isn't chipped right, or your calibration is corrupted.
- Start with a new calibration (make sure your software and firmware are updated).
- Try the S300 in a known-working ECU, make sure datalogging is operating correctly.
- Check the Hondata website and make sure your S300 is not counterfeit.
- Try a different S300 (or ostrich with a double-female header) in your ECU and verify operation.
mikej94civex
11
May 22, 2010 01:40 PM
draxxus07
Sep 29, 2005 11:35 AM
