NEWS: Introducing Hondata K-Pro Version 4
Old 12-08-2014, 10:23 AM
mtber's Avatar
Icon7 NEWS: Introducing Hondata K-Pro Version 4
Pricing is still the same! To order click here!l
Faster and more powerful:
The KPro4 uses a faster processor with more capability than the KPro-III. This allows the KPro4 to perform more tasks without slowing down the ECU, like live tuning, output to a dash, flex fuel and advanced protection. Calibration uploads and datalogging from a laptop are also faster.
Enhanced on board datalogging:
The KPro4 has double the datalogging memory (64 MBit) of the KPro-III and can datalog at double the rate (100 Hz), giving an on board recording time of 10 - 220 minutes.
Faster upload & datalogging:
The upload time is 30% faster than the KPro-III, with a typical initial upload time of 7 seconds. Subsequent uploads are also faster, and live tuning can be used for instantaneous updates. Laptop datalogging is also 30% faster than the KPro-III.
Live tuning & autotune:
Main tables can be updated in real time, without affecting the operation of the engine. This allows dyno tuning without pausing to upload.
Autotune uses live tuning and a laptop to tune fuel tables as you drive.
Bluetooth:
The KPro4 includes Bluetooth for laptop programming/datalogging with a USB cable, and mobile datalogging.
Ethanol sensor input:
An ethanol sensor can be directly connected to the KPro4, allowing flex fuel operation, with adjustments to fuel & ignition tables performed automatically based on fuel ethanol content.
Speed sensor input:
A speed sensor input can be directly connected to the KPro4 and sent to the ECU. This is configurable to any pulse based sensor and eliminates the need for a stock speed sensor.
Dash & datalogging outputs:
The KPro4 has serial output (both TTL & RS232) and CAN output so that a dash can be driven from the KPro. The AiM MXL, Racepak & generic CAN outputs are supported.
Advanced Protection:
Advanced protection options use the KPro4 analog inputs and engine information to intelligently shut down the engine when the conditions might be dangerous to the engine.
Better wideband support:
The KPro4 can process a wideband lambda input (either analog or digital) and allow the ECU to run in closed loop from an aftermarket wideband without requiring the stock o2 sensor.
SJdc5
02-17-2006 11:46 AM
NoVtecLs
10-06-2004 05:54 PM
BLaCk-S
03-18-2004 07:51 PM
VtecInteg95
12-11-2002 08:29 PM
01-0720
02-15-2002 07:33 AM
Quick Reply: NEWS: Introducing Hondata K-Pro Version 4
