Need basemap for built h22
Old Jul 27, 2015 | 11:26 PM
H22aeghatchback's Avatar
Default Need basemap for built h22
Hello Im wondering if anyone has a similar build to mine and can help me out with a map to get to my tuner my car won't stay on spark plugs get wet
Build is: 92 eg hatch on hondata s300 v3
H22a 11.5.1 comp standard spec
h beam rods
Brian crower 3 na cams and BC valetrain
Alpha 70 mm throttle body port matched stock intake manifold
Aem fuel rail and 650cc rc injectors
Pnp exhaust ports
4-2-1 3" exhaust
Any help is appreciated thank you
Old Jul 28, 2015 | 08:14 AM
98vtec's Avatar
moderator emeritus
Default Re: Need basemap for built h22
contact your tuner.
Old Jul 28, 2015 | 10:48 AM
Thanks will give that a try
Old Jul 28, 2015 | 10:59 AM
B20VtecVillain's Avatar
throwing in a set of stock injectors and running a stock H22 Ecu would probably be the safest way to drive it to your tuner if he/she can't give you a remote map for the drive. You should be able to easily pick those items up for cheap.
Old Jul 28, 2015 | 05:46 PM
I'm just trying to get it to turn on and get it on a tow dolly without having to switch back oem parts but it looks like that is what I'll have to do
Old Jul 28, 2015 | 06:26 PM
98vtec's Avatar
moderator emeritus
what sounds more reasonable?
A) asking random people on the Internet for a basemap
B) your tuner supplying you a basemap
Old Jul 30, 2015 | 05:01 PM
VegasInvasion's Avatar
I'm Huge In Japan
as a general rule of thumb you should always start a new thread, even if it's against your better judgment.
there's absolutely no reason to do your own thinking when there's like... thousands of us to do it for you.
djnikko
Aug 7, 2014 02:33 AM
kirilli4
Feb 10, 2013 06:21 PM
alexthegrinch
Engine Management and Tuning
Oct 26, 2009 08:33 PM
5lugSlug
May 25, 2008 09:31 AM
