Hondata help!?
Old Apr 26, 2015 | 01:25 PM
EF'GSRrr91's Avatar
Default Hondata help!?
With my fresh build I'm going to use the hondata s300 v3... Trying to find the best route. I have my stock p72 ecu. Should I just buy the s300 module. Or the s300 ecu package.
Old Apr 26, 2015 | 05:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Hondata help!?
Whatever is in your budget. If you want to utilize the crappy stock knock sensor circuit then send yours out to be socketed or do it yourself.
Old Apr 26, 2015 | 09:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
I'm not sure why this is a question. The P72 is a valuable ECU, and I assume you have one because you have an IAB manifold. Even if not, it's nice to have as an extra output.
Any local tuner should be able to install an S300 in your existing ECU for under $100. Purchase the unit and have it installed and tuned by the same person.
Doobie/ej1
Feb 23, 2011 10:32 PM
EGtoua
Engine Management and Tuning
Apr 28, 2010 03:28 PM
95turbogsr
Jun 26, 2005 09:17 AM
teg92
Dec 13, 2002 06:07 AM
