p28 chip problem
Old Feb 2, 2015 | 03:29 AM
manasel's Avatar
Default p28 chip problem
hello,i've just chipped an p28 and when i put the jumper it doesn't take the map and the check engine light stays on,other strange thing is when i take out the jumper to run the stock map,when i put the ignition on the check engine does a quick blink,not like it should do with a stock ecu.i've tried with other chipped ecu and it works.
Old Feb 2, 2015 | 03:31 AM
B20VtecVillain's Avatar
Default Re: p28 chip problem
What chip are you using and are you sure of the quality of the socket/solder work?
Old Feb 2, 2015 | 03:53 AM
manasel's Avatar
the chip itself works on the other ecu,i've desoldered and solder it again,still the same problem.the single clue is that quick flashing check engine light when i put the ignition with the jumper off.with the jumper on it runs in safe mode and the check engine doesn't go off
Old Feb 2, 2015 | 04:38 AM
92cxturbo's Avatar
Are you 100% certian the ecu worked properly prior to the socket install?
Old Feb 2, 2015 | 07:28 AM
manasel's Avatar
yes it did...not having a clue about what it might have..
Old Feb 2, 2015 | 05:41 PM
GhostAccord's Avatar
What are you using for tuning software and hardware? Do you have any hardware to connect the chipped ECU to a laptop?
Have you tried checking for diagnostic codes on the ECU both with and without the jumper?
Old Feb 4, 2015 | 06:32 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The ECU is most likely toast. About 10+ years ago during my first socket install / VTEC conversion I screwed up and ruined my ECU. It was doing exactly what you say yours is. Some people say there is no way it could of happened but I learned my lesson and moved on - and I never let it happened again.
92civic227
Mar 9, 2005 11:41 PM
BoredRec
Sep 27, 2004 09:31 PM
hybridb18
Feb 17, 2004 07:11 AM
lilxvtecxpwr
Aug 9, 2002 09:14 AM
