problem with my ecu please help
Old Mar 26, 2015 | 11:01 PM
dattyd1's Avatar
Default problem with my ecu please help
hay i think im in the right sort of place...... i have been doing alot of research into chipping stock ecu's and i pulled mine out of my B16A 93 del sol, its a p30 and when i opened it up to check the board number (1720) i noticed that where you put the mod chips and resistors n all that **** already there..... y? all my research i have been doing all day now makes no sense plz help or point me in the right thread. ask if more info is needed.
its P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
thanks in advance
Old Mar 27, 2015 | 04:37 AM
7rrivera7's Avatar
Default Re: problem with my ecu please help
That ECU has been chipped by the factory. The problem is that now you have to remove the chip to install the socket and a blank SST chip to program. Add datalogging pins to CN2 and you are done.
I don't recommend you tackle this yourself if you've never done it or don't have the proper equipment as it's very easy to lift traces when removing the chip.
I do this for a living so if you need assistance, PM me.
PS. I don't think that's a real P30 as it does not have a knock board. It's a -G00 revisión so maybe that one came without knock but since I can't read the CPU code, I cannot validate it.
Old Mar 27, 2015 | 07:28 AM
mtber's Avatar
thanks in advance
As mentioned by 7rrivera7 that is a factory chipped ecu.
The ecu is a real p30, however a G version which has no knock or atmospheric pressure sensor.
Unless you have the proper equipment and experience on modifying cirquit boards you should not try to chip the ecu your self.
You should mail the ecu in to be chipped or buy a pre-chipped ecu.
Check out Phearable.net for more information.
Old Mar 27, 2015 | 12:35 PM
dattyd1's Avatar
so its been factory chipped, are data logging pins able to be added to tune this chip or is a blank sst chip still needed? and where can i find the cpu code ill post it up, knowledge is power the more i can find out the better i know what im dealing with
Old Mar 27, 2015 | 03:39 PM
GhostAccord's Avatar
Wow.... is that a UV based EPROM chip? It's been at least 15 years since I last saw one of those.
You will need to remove that chip and have a socket installed. Most tuners don't use chips for tuning anymore. They use a ROM emulator like the Moates ostrich, Neptune Demon or Hondata hardware.
If you want you can start reading this; http://static.moates.net/zips/crome/...ME%20v1.06.pdf
Old Mar 27, 2015 | 03:45 PM
Muckman's Avatar
Moderator in Chief
Why would that be chipped from the factory like that?
Old Mar 27, 2015 | 04:30 PM
dattyd1's Avatar
yea i have that pdf and have been reading it and it is very detailed and hard to understand but ill get there. in regards to the EPROM chip is it tuneable? is there any performance difference between factory tuned and not factory tuned? and also is it just that chip that needs taking out and not the others that come with aftermarket chip upgrades? one last minute thing iv been looking at these here in NZ what do you think about them? 92 - 96 Honda Del Sol B16A2 ECU Upgrade Chip | Trade Me
Old Mar 27, 2015 | 05:34 PM
dattyd1's Avatar
also having trouble logging into pgmfi.org ? Index page so ill ask here. are the "new" base maps that come in crome the same as the stock ecu maps? and what one should i use for mine? 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR P30-G00
im guessing the P30G EDM civic B16A2. my engine is a B16A2 btw
Old Mar 28, 2015 | 05:16 AM
7rrivera7's Avatar
Looks like the CPU code is "230" which makes this ECU a P28 and not a P30.
When using Crome, you should start with a P30 map as it has the most support.
Old Mar 28, 2015 | 10:44 AM
dattyd1's Avatar
sweet thanks for all this fulaz would have never known this on my own. ill probly post here again sometime about somthing lol, thanks again
Old Mar 28, 2015 | 10:45 AM
dattyd1's Avatar
1 last thing before i go, y does the ecu chassis say p30 - g00 if its really a p28? and where did you find the cpu code?
Old Mar 28, 2015 | 11:11 AM
I would imagine that it is a factory reprogrammed P28 board/chipset (Oki 66x CPU ID number 230). They would have re-labeled it as a P30 because that is probably the tune is on the extended EPROM chip (Oki 80).
The 66x CPU ID number on a P30 chipset would be ether 245 or 246.
The PGMFI.org Library has a list of all the ECUs and there processor code numbers.
Old Mar 28, 2015 | 11:42 AM
7rrivera7's Avatar
CPU code 230 is the large number on the biggest chip
coryfenton
13
Jul 16, 2009 04:18 PM
JDM B16A
31
Apr 11, 2006 05:01 PM
hybrid_vtec
Sep 3, 2004 08:20 AM
100whplusperliter
Aug 9, 2003 11:35 PM
Mr. Softee
Jul 23, 2003 01:11 AM
