Sst chip identification
Old Jul 15, 2015 | 05:13 AM
toony's Avatar
Default Sst chip identification
Hello. Recently i've been tuning a few cars. A few days ago some guy wanted me to burn a map onto his chip so i told him to give me the chip. I noticed that his sst chip was a little different than mine. It had "sst mtp" written on it instead of just 'sst' as on my chips. My question is whether they are the same chips and whether i can burn a map onto the 'sst mtp' chip using moates chip burner? Looking for any helpful responses, thanks.
Old Jul 16, 2015 | 02:42 AM
7rrivera7's Avatar
Default Re: Sst chip identification
Most likely a clone or the newer style but inferior replacments that are available. High failure rate. I do not use them. If it takes the burn and verifies, tell the client you can't garantee how long it will work.
New style SST 27SF512 Chip problems - Third Generation F-Body Message Boards
Old Jul 16, 2015 | 07:12 AM
toony's Avatar
Thank you for the reply. I ended up giving him the map on my chip instead.
Old Jul 17, 2015 | 11:55 AM
HAMOTORSPORTS's Avatar
We have seen a lot of the "MTP" stamped chips coming through as well. These are a China and/or Taiwan clone of the SST chip. Most only accept a burn/program one time. If you try to overwrite the burn a second time it will usually not accept the burn.
Old Sep 8, 2015 | 08:05 PM
VegasInvasion's Avatar
I'm Huge In Japan
same here, those MTP knockoff chips are total garbage.
Old Apr 4, 2021 | 12:55 AM
A D's Avatar
A D
Sorry I'm new to this whole do it yourself machine **** with hondas. So when you guys say burn. Are you talking tuning the chip? Or am I mistaking that term? Only curious cause I just looked at my ecu I got n it has the sst mpt chip in it.
lkailburn
Dec 31, 2015 03:03 PM
butter99
Jul 20, 2010 05:20 PM
Honda4life777
Engine Management and Tuning
Jul 11, 2009 09:39 PM
slambedcivic
Jul 14, 2006 08:00 AM
ATS*Mark
Oct 12, 2004 04:52 PM
