Converting from Neptune to Hondata?
Old Apr 21, 2015 | 06:47 PM
JDMEMone's Avatar
Default Converting from Neptune to Hondata?
So I have a socketed ecu that's running on a Neptune chip. I am wanting to change to he new Hondata s300 v3. Is there any easy way to take the the tuned Neptune Map and covert it to the new s300? Thank you in advance!
Old Apr 21, 2015 | 07:29 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Converting from Neptune to Hondata?
You can't do it. Even if you copied every single thing individually it will be off. The data is pretty much just random numbers after all... Your best bet is to get a full retune.
Old Apr 28, 2015 | 02:47 PM
Aradin's Avatar
Premium Member
I just did something similar with a chip based Crome setup to Neptune RTP & a Demon II. Tried to copy/paste the Crome fuel maps to Neptune so I would have a solid base and even though they were the same in both programs Neptune ended up being way richer.
I'm with OneBad on this. If you switch you should have the car tuned again.
civel
Jan 24, 2006 08:58 AM
youngvedder
Jul 27, 2005 11:36 AM
philo
Mar 17, 2003 09:11 AM
morepoop4u
May 11, 2002 02:36 PM
