Engine Running Lean
Old Aug 7, 2015 | 01:33 AM
drivingshadow's Avatar
Icon4 Engine Running Lean
What would cause engine to run in a lean condition, car is ls vtec turbo has Hondata s300 grams injectors Grams fuel pump, wide band reads very lean after 1/4 throttle erratic rpms. I can get the car rolling and switch the ignition from the key on engine off to the key on engine on position pulls fine then goes lean push throttle no response switch ignition from "koeo" to "koer" car pulls again then 5 to 7 seconds lean again same cycle.
Old Aug 7, 2015 | 10:37 PM
ThE HeLLRaZoR's Avatar
Default Re: Engine Running Lean
Soon you'll possibly have to change your name to DrivingGhost
If it go's lean and falls on it's face, i'd say that's a great indication you should stop driving it until you findout whyXD
Old Aug 8, 2015 | 04:02 AM
Muckman's Avatar
Moderator in Chief
Sounds like a tuning issue. Add more fuel or take it to a tuner.
existanzcivicb20
Feb 18, 2014 05:55 AM
balbowskie
Apr 26, 2012 06:37 PM
turbo-d
Feb 4, 2005 04:58 PM
VTgringo
Aug 18, 2003 06:50 AM
blacksheep
Aug 14, 2002 07:21 PM
