Can someone help on standalone ecu..please
Old Apr 14, 2015 | 01:46 PM
jfpAtom3's Avatar
Default Can someone help on standalone ecu..please
I have a 2011 K20z3 (drive by wire)
Is there a standalone ECU that will work for me to plug & play to my harness?
I want to do a force induction project -- can someone advice me what
standalone ECU that I need to buy.
thank you
Old Apr 14, 2015 | 03:11 PM
Spunkster's Avatar
Default Re: Can someone help on standalone ecu..please
FlashPro
Old Apr 14, 2015 | 03:44 PM
ArniFPR's Avatar
megasquirt ;D the best would be just install a normal throttle body and pedal
Old Apr 15, 2015 | 10:32 AM
jfpAtom3's Avatar
If I use mega squirt will I be able to use my wiring harness and the plug without buggering or cutting it?
Old Apr 16, 2015 | 12:49 PM
evo_lucian's Avatar
Yes. The beauty of megasquirt is that there are dozens of ways to skin that cat. Give the guys at diyautotune.com a call and they will be happy to answer all your questions
Old Apr 23, 2015 | 01:46 PM
jfpAtom3's Avatar
Thank you.....one more question.
If I go for Flashpro instead of buying standalone ecu, Is the Flashpro and my stock honda ecu can handle force induction mapping?
Old Apr 23, 2015 | 09:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes it can. FlashPro has both fuel and ignition tables for boost.
Old Apr 24, 2015 | 06:01 AM
jfpAtom3's Avatar
Flashpro will be my first choice due to the reliability of the Honda stock ECU.
But I researched and found out that flashpro is only specific to the serial # of the ECU. It will not work to anyone's ECU.
What happen if I break my current ecu and pick up another used one?
Do i have to buy another flashpro?
Old Apr 26, 2015 | 08:39 PM
VegasInvasion's Avatar
I'm Huge In Japan
The chances of you breaking your ecu is extremely unlikely. But if you registered your flashpro, you can send it and your new ECU to Hondata and they should be willing to remarry it for you.
Megasquirt is a good option, AEM EMS is also a good standalone (and better developed IMO). I personally choose standalone over Flashpro because I don't condone monopolies, and Hondata's UI is elementary at best. But either will do the job.
Alternatively you can also use the AEM F/IC6 piggyback for considerably less without sacrificing OBD, however it isn't as comprehensive *as* your other options. It does have its own injector drivers, map sensor, independent fuel & ignition tables, and a closed loop/O2 adjustment table. The software has pretty modern datalogging functions, real time updating, etc.
salvagetitlesil
Apr 4, 2012 12:15 AM
nicko360
Mar 28, 2007 03:59 PM
Solscud007
Jan 10, 2006 10:58 AM
white_panther
Oct 7, 2005 06:24 AM
HX_Guy
Nov 12, 2001 04:17 PM
