Open loop control
Old Dec 4, 2014 | 04:31 AM
Treyschls's Avatar
Default Open loop control
Anyone got any info on open loop tuning and proper way to induce open loop.
Old Dec 4, 2014 | 01:51 PM
LTCxD2B's Avatar
Open loop just means the O2 is not compensating the fuel tables so it's the same as having no O2 ... This is done in order to get readings on a wideband directly from the fuel map and not a compensated value based on the O2 corrections
Old Dec 4, 2014 | 04:31 PM
Treyschls's Avatar
Default Re: Open loop control
So all I need to do is remove the O2. What about a check engine light.
Old Dec 4, 2014 | 05:43 PM
theYBLEGAL's Avatar
Loved
You have a lot to learn OP.
http://www.ej9.ru/data/book/crome-v1...pro-dealer.pdf
Old Dec 4, 2014 | 08:18 PM
Treyschls's Avatar
so I take it that there isn't any methods that a can be done without that type of system
Old Dec 4, 2014 | 09:43 PM
theYBLEGAL's Avatar
Loved
There is no jumper or hack to force open loop other than using an ECU editor such as those systems. Yes.
Old Dec 8, 2014 | 02:34 AM
joakwin's Avatar
hondata has a drop down menu to put the ecu into open loop
Hondata s300 Programmable ECU Guide
$amGD3
22
Feb 24, 2021 06:12 PM
BoldFart16
Engine Management and Tuning
12
Mar 12, 2011 06:09 AM
domino
Sep 29, 2005 07:47 AM
Quick 200k Mile Motor
Sep 13, 2002 06:19 AM
Atiyeh
Jul 14, 2001 07:10 PM
