S300
Old Jun 26, 2008 | 01:05 AM
gettin it's Avatar
Default S300
Ok, im about to make the cross over from crome to the s300 hondata. My question is, do it matter what ecu the s300 is installed in? My homie said the ecu isn't labeled on the outside and he hasn't looked inside since he just got it. Everything is new and obd 1. And info will help out alot. ]
Thanks
Old Jun 26, 2008 | 01:23 AM
gcsd3742's Avatar
Default Re: S300 (gettin it)
I just did the Hondata S300 upgrade and it is badass good luck
Old Jun 26, 2008 | 02:34 AM
gettin it's Avatar
Default Re: S300 (gcsd3742)
Thanks what ecu did you use?
Old Jun 26, 2008 | 06:31 PM
mtber's Avatar
The supported s300 ecus are listed on hondata.com
I.e. p06, p05, p28, p72 etc...
Old Jul 3, 2008 | 01:01 AM
gettin it's Avatar
Default Re: S300 (mtber)
Ok, i got the system a few days ago. But im unsure what ecu it is. Phearble you guys say thats its a p28 but it doesn't say it anywhere on the ecu. It just have your sticker on it. Is there anyway of knowing for sure?
Old Jul 3, 2008 | 02:10 AM
ralph11sec's Avatar
there is a code written on the board. look for it. and search in pgmfi the board number.
Old Jul 3, 2008 | 12:41 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gettin it &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i got the system a few days ago. But im unsure what ecu it is. Phearble you guys say thats its a p28 but it doesn't say it anywhere on the ecu. It just have your sticker on it. Is there anyway of knowing for sure?</TD></TR></TABLE>
If you got the ecu from us it is a p28, p05, p06 ecu which is hondata compatible.
Contact us directly for upgrade options from crome to hondata
JDM91EF2
22
Dec 23, 2006 02:38 PM
JDM95lude
Oct 1, 2006 02:01 PM
JeffBro
Nov 12, 2005 11:32 AM
