Help wiring aem 3.5 bar map sensor.....
Old Aug 8, 2008 | 11:18 AM
stpacura's Avatar
Default Help wiring aem 3.5 bar map sensor.....
Ok so I have and obd1 hardness and I'm trying to wire the aem 3.5 bar map sensor to the hardness.
The aem map sensor plug comes with three wires(Green, black, and red) same as the stock plug on the obd1 hardness except the wires color change. On the oem plugs(I say plugs because their two plugs exactly the same, but I know one is for the throttle position):
One: has green/white, red/blue, and yellow/white
Second: has yellow/red, blue/white, and white
Ok now my question is which of these is the map sensor and what each wire means. I know one is SUPPLY VOLTAGE, one is GROUND, and last one OUTPUT.
Can anybody help me plz.
Old Aug 8, 2008 | 05:16 PM
stpacura's Avatar
Default Re: Help wiring aem 3.5 bar map sensor..... (stpacura)
anyone plz.....................
Old Aug 8, 2008 | 06:47 PM
stpacura's Avatar
por favor respondan..........
Old Aug 8, 2008 | 10:35 PM
mtber's Avatar
On the factory honda harness: Yellow is power, White is signal, Green is ground.
Rand The Man
20
Sep 18, 2013 05:32 AM
I B BANGGIN
Feb 6, 2007 07:50 PM
paul93sir
May 31, 2005 03:53 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
