Ecu help?
Old Jun 18, 2008 | 10:05 AM
EGcoupe2.0vtec's Avatar
Default Ecu help?
Im building a '99 civic si and i know to run hondata s300 i have to use an obd1 computer..Prolem is i do not know which obd1 computer to get..can i buy a p28 or is there a specific one i have to get to run with my car..the engine is a b16a2..please help im not good with ecus
Old Jun 18, 2008 | 11:55 AM
98vtec's Avatar
moderator emeritus
Default Re: Ecu help? (EGcoupe2.0vtec)
are you installing it?
you know you can likely buy an ecu from a hondata dealer with it already installed. That way when it comes to you, it's already done and has a basemap loaded. All you gotta do it plug it in
unless you want to install it yourself, then dont listen to me
Old Jun 18, 2008 | 12:04 PM
Default Re: Ecu help? (98vtec)
would phearable sell those? or a company like them...and what would i do with my odb2 computer jus hold on to it if i decide to ever go back to stock or toss it
Old Jun 18, 2008 | 09:22 PM
mtber's Avatar
You can buy a hondata s300 unit pre-installed in a obd1 ecu
You will need an obd2 to obd1 jumper (plug & play harness) aswell.
If you have any further questions, feel free to ask away
Old Jun 19, 2008 | 02:51 PM
Default Re: Ecu help? (mtber)
does it also come with a base tune installed or is it like aem where u have to tune the car to even run? also how easy is it to tune with?
Mr. Chainsaw
Engine Management and Tuning
Mar 30, 2009 08:11 PM
connor53
Oct 5, 2008 02:15 PM
otakueric
10
May 22, 2004 06:07 PM
yellowbuffalo
Oct 28, 2003 07:11 AM
yellowbuffalo
Jun 2, 2003 06:24 PM
