obd2b auto b20b ecu
Old Jun 21, 2008 | 06:53 AM
socallmechris's Avatar
Default obd2b auto b20b ecu
i have 99 civic ex and im swapping to a b20b. i plan on swapping out the head and going b20v down the road a bit. for the time being i need an ecu for the b20b and im finding alot of automatic ones.
would an obd2b auto ecu work with my stock harness and what do i have to do to convert it to manual? i don't know if the procedure is the same to convert obd1 and obd2
Old Jun 21, 2008 | 11:35 PM
mtber's Avatar
Default Re: obd2b auto b20b ecu (socallmechris)
I would recommend you use an obd2 to obd1 jumper harness & a chipped obd1 ecu for performance use. For emissions inspection (if you have it) go ahead and run a obd2 p75 5 speed ecu (from a 96-99 integra ls,gs,rs).
For more information on what a jumper harness & chipped ecu is read over http://www.phearable.net/tech/....html
98_ls_dc
Engine Management and Tuning
Mar 16, 2010 02:59 PM
beandc2
Jan 4, 2010 04:59 PM
Joeski99Si
Sep 4, 2008 10:18 AM
99ekb18b
May 29, 2007 06:41 AM
4drb18ek
Mar 1, 2003 07:42 AM
