Question about phearable.net
Old Aug 27, 2008 | 06:32 AM
zach1288's Avatar
Default Question about phearable.net
I am getting ready to boost my car and i have a few questions about the ECU's offered by phearable.net. When i buy a chipped ECU with crome for 150 dollars is that all i need for my tuner to tune my car? I know i need the OBD2-OBD1 conversion harness as well. How do you interface a laptop with the ECU?
Old Aug 27, 2008 | 07:11 AM
Tomdata's Avatar
Default Re: Question about phearable.net (zach1288)
Start off by reading this...
http://forum.pgmfi.org/viewtopic.php?f=40&t=12477
then keep reading stuff on the pgmfi forum and you can learn everything you ever wanted to know about honda OBD0 and OBD1 ecu's.
Old Aug 27, 2008 | 07:42 AM
zach1288's Avatar
Default Re: Question about phearable.net (Tomdata)
So if i understand correctly you can either purchase an ECU with USB or an ECU that you have to use a chip burner. Am i correct? Where can i buy an ECU with USB and crome?
Modified by zach1288 at 11:52 AM 8/27/2008
Old Aug 27, 2008 | 08:59 AM
98vtec's Avatar
moderator emeritus
http://store.ectune.com/Shop/t....aspx
Old Aug 27, 2008 | 09:12 AM
mtber's Avatar
Read: http://www.phearable.net/tech/....html
It should explain how it all works to you :-)
jthrasher1
Jan 25, 2010 08:41 PM
stevenDAtegra
Engine Management and Tuning
12
Dec 18, 2009 09:37 AM
PrestonCRX
Mar 16, 2006 06:09 PM
trinihonda
Dec 3, 2005 11:51 AM
dhvyse
Nov 2, 2003 02:42 PM
