idle surging.... please help!
Old Jul 24, 2008 | 06:08 AM
j0keefe21's Avatar
Default idle surging.... please help!
i have a 94 civic dx with 173k on it and the idle surges going up and down... i have no clue what it is but when i unplug the sensors on the throttle body then plug them back in its fine again.. any help would be great thanks
Old Jul 25, 2008 | 02:55 PM
yakuza's Avatar
Sounds like an air leak. Check all your vacuum lines and double check the TB gasket.
Old Jul 25, 2008 | 08:57 PM
mtber's Avatar
Default Re: (yakuza)
Check the fast idle thermo valve. fitv (search)
Old Jul 31, 2008 | 07:38 AM
w0ng_sta's Avatar
Default Re: (mtber)
vac leak.. maybe bubble in coolant.
Old Aug 7, 2008 | 12:08 PM
Scheizty's Avatar
Default Re: idle surging.... please help! (j0keefe21)
Sounds like you are getting erratic readings from the sensors. Check the signal voltages and make sure they are consistant.
weaslehunter1
Jan 26, 2015 03:49 PM
luv2boost
Jun 2, 2008 06:33 PM
PhilMac
Jan 14, 2008 11:35 AM
deeweezy187
Dec 3, 2005 08:50 PM
BME1986
12
Jul 13, 2004 04:57 AM
