engine dies when running with a/c
Old Jul 1, 2008 | 04:28 PM
ralph11sec's Avatar
Default engine dies when running with a/c
i'm tuning a friend's car.
bseries 2L
1000cc
air intake manifold (iacv is isolated)
gt35
so it's like this. it idles at 800-900 fine, without a/c when i tip in the throttle to like 4trpm, when it goes down, it reached around 500rpm and revives the idle speed.
but when i turn on the AC, no matter what idle speed i run it, EVEN 1.5trpm idle, after a tip in, it goes down straight and engine dies on me.
i tried aem, s300, crome.
tps is set to 0, tried ign from 5 - 20, fuel is okay, vacuum at idle without ac is 250mbar, and with a/c is 350mbar. (too much vacuum?) cam gears are at 0,0.
Old Jul 1, 2008 | 04:49 PM
mtber's Avatar
Default Re: engine dies when running with a/c (ralph11sec)
Check your a/c system's pressure make sure it is not too high...
Old Jul 2, 2008 | 12:34 AM
ralph11sec's Avatar
Default Re: engine dies when running with a/c (mtber)
how high is too high?
is 250mbar @ idle 800rpm no a/c too low? because my car idles at 800rpm also and i get around 450-500mbar. i know i dont have any leaks because turbo is spooling pretty nicely with no boost leak.
Old Jul 3, 2008 | 02:32 PM
romerosi's Avatar
hey i have a gsr with a jackson charger on it, with a chipped p28 by jktuning
my car does the same exact thing, it drives perfectly fine with the a/c on but when i come to a stop it dies, not evry time but often ive also tryed everything
Old Jul 3, 2008 | 04:00 PM
HRTuning's Avatar
Default Re: engine dies when running with a/c (romerosi)
Was it chipped or did you actually have it tuned? Talk to JK about making the appropriate adjustments.
Old Jul 3, 2008 | 08:42 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralph11sec &raquo;</TD></TR><TR><TD CLASS="quote">how high is too high?
is 250mbar @ idle 800rpm no a/c too low? because my car idles at 800rpm also and i get around 450-500mbar. i know i dont have any leaks because turbo is spooling pretty nicely with no boost leak.</TD></TR></TABLE>
Check the helms manual for factory specs.
OverBoostDemon
Nov 4, 2009 02:55 AM
jdm samurai
Jul 12, 2006 07:46 AM
blk_eg4
12
Jun 21, 2006 08:31 AM
turboB16RFD
Oct 9, 2005 09:15 PM
confucius
May 23, 2005 10:18 PM
