Having issue with HONDATA S300.
Old Jul 3, 2008 | 09:40 PM
95exdsmkilla's Avatar
Default Having issue with HONDATA S300.
Like the topic says,
I tried PMd Hondata forum.. NO help at all. anyways the problem is, somtimes I see Green and Red Light at the same time and I was not datalogging at all. Most of the time it is Solid green.
I know someone on here knows.. Please help thank you.
Old Jul 3, 2008 | 09:59 PM
Garage 808 Hatch's Avatar
Default Re: Having issue with HONDATA S300. (95exdsmkilla)
do you have an aftermarket ignition box mounted near it?
Old Jul 3, 2008 | 10:01 PM
EXPO 000's Avatar
is your onboard dataloggin enable if so it might be activating with the setting you have in the software
Old Jul 4, 2008 | 05:12 AM
Default Re: Having issue with HONDATA S300. (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">do you have an aftermarket ignition box mounted near it?</TD></TR></TABLE>
my aftermarket ignition box is in my engine bay.
[QUOTE=is your onboard dataloggin enable if so it might be activating with the setting you have in the software
[/QUOTE]
No on board dataloggin is disenabled.
Old Jul 4, 2008 | 10:34 AM
flesh199's Avatar
you can update your usb drivers first.
Look like you s300 can see your laptop so you have a problem with your connection i think...
Old Jul 5, 2008 | 11:08 AM
Default Re: Having issue with HONDATA S300. (flesh199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flesh199 &raquo;</TD></TR><TR><TD CLASS="quote">you can update your usb drivers first.
Look like you s300 can see your laptop so you have a problem with your connection i think...</TD></TR></TABLE>
usb driver updated.
make good connection. still having green and red light at the same time.
Old Jul 8, 2008 | 10:03 AM
Spunkster's Avatar
Ignore the lights and describe the actual problem you are having.
Old Jul 13, 2008 | 01:11 AM
boostedgsreg's Avatar
i am having a similar problem but instead of green and red it changes to solid red from time to time... turn the car off and start it again and it is grean
Old Feb 9, 2011 | 11:04 PM
215HPLSVTEC's Avatar
I got that problem runs fine Intell I try too get on the the gas and let vtec open that red light light comes on so I let off it won't go away so I push the clutch in and car drops to ideal the red light goes away. So I give another pull in third and it comes on again so I let off it won't go away so I push in the clutch then back to ideal then back to green. Any info would help thanks guys.
Old Feb 10, 2011 | 06:42 AM
HAMOTORSPORTS's Avatar
You have on board datalogging enabled and when it meets the specified datalogging parameters it is datalogging. If you are concerned with it, simply disable on board datalogging.
NJIN BUILDR
Jul 30, 2008 07:42 PM
gsrt
Jul 23, 2008 06:13 PM
dreed2300
Nov 5, 2006 07:21 AM
redskittle
May 10, 2006 07:09 PM
ladysman
May 27, 2005 10:03 AM
