Greddy E-Manage
Old Jul 29, 2008 | 08:53 PM
rustydusty1717's Avatar
Default Greddy E-Manage
Currently got a b16a2 with a greddy turbo kit running the greddy e-manage. it comes pre-tuned for 6 psi now if i was to get a manual boost controller and bump it up to 8 psi will i need to get it re-tuned? talked to my local speed shop and guy was talking about a timing harness i need to get for the greddy e-manage. not looking to make huge power. 8 psi will be highest i go for now so i just need to hear it from some professionals that i'm good to go and just put the boost up.
Old Jul 30, 2008 | 07:32 AM
Tomdata's Avatar
Default Re: Greddy E-Manage (rustydusty1717)
I always suggest getting rid of the e-manage to all of my customers and just getting the car tuned on one of the many OBD1 rom editors available today. If your car is an OBD2 car then you should convert to OBD1 and get it tuned.
Old Jul 30, 2008 | 11:23 AM
mtber's Avatar
As tomdata said, get rid of the emanage & switch to an obd1 engine computer system such ad Hondata.
Read over https://honda-tech.com/zerothread?id=1544043 for more information.
Old Jul 30, 2008 | 02:55 PM
why would i spend couple hundred MORE to get hondata just to put the boost from 6-8 psi. especially if e-manage will do the trick.
Old Jul 30, 2008 | 04:34 PM
Tomdata's Avatar
Default Re: (rustydusty1717)
its not at all about the money. And no one is trying to sell you anything here. The truth of the matter is that e-manage does not compare to most of the obd1 rom editors out there. If you want it to be the best it can be then get rid of then follow our advice. If you want to not spend any more money then turn up the boost and retard the distributor a few degrees. Then cross your fingers and hope nothing bad happens.
Good luck with whatever you decide.
Old Jul 30, 2008 | 04:40 PM
well i don't want to spend anymore money right now. i've spent enough money on the car this year. if i was to turn the boost up only 2 psi what all do i have to do? does the e-manage have to be re-tuned?
Old Jul 30, 2008 | 08:41 PM
mtber's Avatar
You are going to end up spending a lot more money then you want to when your emanage system tune destroys your motor due to not having proper ignition timing retard at a higher boost level etc.
Do it right or don't do it at all
Old Jul 31, 2008 | 03:10 PM
anyone who actually has e-manage comment on this?
if i simply can't turn the boost up and get e-manage re-tuned what is the cheapest way to safely tune my car. also what's the max HP to run on 310 cc in jectors?
Old Jul 31, 2008 | 04:36 PM
kinday's Avatar
Buddy...the E-manage will be able to run your car and run it pretty decently
NOTE....the Rom editors like hondata, Crome, etc will do a far better job.
You're going to have to retune to accomodate the extra 2 psi....just get on the dyno with a decent tuner and you'll be ok. You will have to get the timing harness if you want to properly use the E-manage capabilities....other than that you'll be adjusting the distributor like someone mentioned earlier and that won't cut it very well. In your case it's easier to sell the E-manage and get the ROM editor since you don't have all the components. Either way it's your ride and your decision, but if you do decide in the future that you need more or you want a more efficient tune then SERIOUSLY look into a ROM editor.
Hope that helps
Old Jul 31, 2008 | 04:52 PM
okay what would you say is the best tuning software then? and what all would i have to do to get the car running with this. first time doing this sorry. does it come with something i need to plug into my ecu and that's how they tune it?
Old Aug 2, 2008 | 01:11 PM
kinday's Avatar
Use the FAQ....or read the link mtber posted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">As tomdata said, get rid of the emanage & switch to an obd1 engine computer system such ad Hondata.
Read over https://honda-tech.com/zerothread?id=1544043 for more information.</TD></TR></TABLE>
Old Aug 4, 2008 | 12:11 PM
accord2nrz's Avatar
Default Re: (kinday)
I have the emanage blue installed on my car, yes you will need to re-tune it. Get the igniton and injection harness and unlock your emb.
Old Aug 17, 2008 | 07:56 PM
ignition and injection? i've got the timing one ordered. is that what you meant?
how hard is it to tune the e-manage? if i can i might get the software and do it myself. otherwise i gotta pay a local shop to do it for me.
Old Oct 17, 2008 | 04:16 PM
accord2nrz's Avatar
sorry for the late response, the emanage is really almost no good unless you get all of it's options and unlock it. If all you have is the timing one that is the ignition harness, You should look for the injection harness as well. If your car is obd2 and you want to keep it that way get the o2 signal adapter which wires into your vtec cross over point giving a point in which to send your car into open loop at a setable RPM alowing you more freedom to tune on your own.
Tuning is isn't hard once you get started. However it's not something you can just jump into and be good to go. I would suggest a knocklite also
97uswagon
Aug 14, 2012 04:14 PM
Liu Kang
Aug 1, 2007 06:23 PM
sd_ep3
Feb 22, 2004 09:03 PM
SupaTeg
Dec 10, 2003 10:29 PM
SIK IN DA HED
Mar 18, 2002 07:53 AM
