need help with motec
Old Aug 15, 2008 | 05:51 PM
turbociv910's Avatar
Default need help with motec
hello, im in the process of gettiny my car running, and i do n ot have my alternator hooked up. I do not know if the alt needs a power signal or ground signal to turn on. i have this diagram, i know its the blue wire, i just need to know if i need to wire the relay as a ground or a power.
Old Aug 17, 2008 | 07:54 AM
Turbogixxer's Avatar
You need to give the Black/yellow switch 12v power. The signal coing from the ECU is not needed or the warning lamp.
Old Aug 17, 2008 | 11:34 AM
Default Re: (Turbogixxer)
ony of my outputs is a alternator, should i wire in a realy to give the alternator its needed 12v switched source
charosenz
Honda Civic (2006 - 2015)
Jan 17, 2018 08:32 PM
California98Civ
18
Dec 20, 2011 02:40 PM
joeymc13
Audio / Security / Video
20
Oct 8, 2010 04:15 PM
Kris's turbo
Sep 18, 2010 06:53 PM
