Copy ecu chip without removing it?
Old Jun 29, 2008 | 08:19 PM
Dxs's Avatar
Dxs
Default Copy ecu chip without removing it?
Want to make a copy of a ROM on a PR3 ecu..
and was wondering if there is any way to do this that does not involved desoldering the chip itself?
Old Jun 30, 2008 | 08:20 AM
98vtec's Avatar
moderator emeritus
Default Re: Copy ecu chip without removing it? (Dxs)
you dont have to desolder anything to remove the chip.
Old Jun 30, 2008 | 09:26 AM
HRTuning's Avatar
Default Re: Copy ecu chip without removing it? (98vtec)
Get a test clip.
Old Jun 30, 2008 | 07:15 PM
Dxs's Avatar
Dxs
so using a 28pin test clip is ok?
it is ok to dump the bin eventhough it is still soldered into the ecu?
Old Jul 1, 2008 | 09:05 PM
Dxs's Avatar
Dxs
well i have a test clip that connects to my moates chip programmer
now i can read 27sf512 chips that i have programmed using my test clip setup
but i havent had any luck with chips on ecus
the binary files are inconsistant
what chip should i use in the flash and burn program etc?
ideas?
Old Jul 1, 2008 | 10:27 PM
Dxs's Avatar
Dxs
Default Re: (Dxs)
is there a special setting/software to use when copying a stock ecu chip??
Old Jul 2, 2008 | 12:48 PM
Relic1's Avatar
be sure that the Burn1 software is set to the right rom type. (what ever is in the socket location)
Old Jul 2, 2008 | 09:02 PM
Dxs's Avatar
Dxs
well there is no corresponding code
the IC in the ecu is
m38256AP-58
(oki japan 9816G)
Old Jul 2, 2008 | 09:10 PM
Dxs's Avatar
Dxs
and i am just getting inconsistant binaries
Old Jul 3, 2008 | 06:54 AM
Relic1's Avatar
I don't know OBD0 stuff well enough to answer.
But I do know this... is your ECU listed in this list?
http://www.b18c5eg.com/EcuDefinitionCodes/
if it is, and there's a bin attached to it, you may not have to pull anything.
Old Jul 3, 2008 | 09:39 AM
HRTuning's Avatar
Default Re: (Relic1)
Use 27256 or 27c256
Old Jul 3, 2008 | 04:37 PM
Dxs's Avatar
Dxs
i have tried 27c256
and verification with buffer never is successful
people have said i need to pull the chip
and a testclip wont work hrtuning
i am leaning towards this
or have you been successful with the procedure
the thing is, it is believe to be a spoon ecu... my friend wants me to check the maps for him
Old Jul 5, 2008 | 10:38 PM
HiProfile's Avatar
Default Re: (Dxs)
You may have to get a willem burner to read the chip. The Burn1 was designed for a handful of chips, and some may not work. The willem works with almost everything.
Given how easy it is to desolder chips with the solder-sucker I see in that picture, you should try that route if all else fails.
Old Jul 6, 2008 | 09:44 AM
HRTuning's Avatar
Default Re: (HiProfile)
Make sure the pins are in the right order and that they're all making contact correctly.
Old Jul 6, 2008 | 09:32 PM
Dxs's Avatar
Dxs
well i can program and read a SST chip by itself
but on the ecu it doesnt work
would rather not desolder (not my ecu, and is believed to be a spoon ecu)
so maybe the burn1 cant read oem IC's?
Old Jul 10, 2008 | 01:40 PM
Nuno Cruz's Avatar
Default Re: (Dxs) Hi! Same Problem!!
Hi !
I also having that problem,a can read and burn the chip,but in the ecu the chip doesn't work,im using a willem programer with the pcb5.0 programer. im using a ST 27c256 chip.
I can't find whats wrong!
Did you find any soluction?
Please let me know if you do,i realy need to tune my car since now its boosted :s
Best Regards people!!
Old Jul 10, 2008 | 04:46 PM
zccr-xsi's Avatar
im not sure on this but ive had the same probelms when trying to read a stock chip.not sure on this so im just taking a shot in the dark but i think honda may have found a way to lock it so the stock rom cant be tampered with.if u want to open or see a stock .bin just d/l it from a rom dump and look at it.that and i dont think the burn 1 is compatible with okie style chips.try calling moates and see what he says!
Old Jul 10, 2008 | 06:11 PM
Dxs's Avatar
Dxs
well how do people dump stock chips then
maybe that is the answer
i doubt the chip is locked in anyway.. or else how do people post the binary dumps on the net
Old Jul 10, 2008 | 09:28 PM
HRTuning's Avatar
Default Re: (Dxs)
Even if it was locked there'd still be people who get around it.
I remove it or use a test clip.
Old Jul 10, 2008 | 09:59 PM
Dxs's Avatar
Dxs
Default Re: (HRTuning)
how do you use the testclip hrtuning
do u use the moates burner?
Old Jul 11, 2008 | 04:11 AM
Nuno Cruz's Avatar
Default Re: (Dxs)
No,it no the stock chip...i can read in the programer a "Chipped chip" that i bought here in my country,and i also can read another chip i buy from the ebay.
i also can do a bin map in the Bre and then burn it in the chip,everything goes fine so far,the only problem its when i put the chip in the ecu,first i couldn't pass 4k,5k..now with a few changes in bre i only keep a solid cel...but that can be because of the changes i made...anyways,the ecu can't read the chip correctly...
There is some hex numbers or something like that to configure before burne the chip? im using 6,25v to burn the chip,the other choises the willem do it automaticly.. i always erase the chips before use with the UV...i presume im doing everything correctly...just the configuration of the willem programer im not sure..
Old Jul 11, 2008 | 04:38 AM
GhostAccord's Avatar
Default Re: (Dxs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dxs &raquo;</TD></TR><TR><TD CLASS="quote">well how do people dump stock chips then
i doubt the chip is locked in anyway.. or else how do people post the binary dumps on the net</TD></TR></TABLE>
I'm pretty sure the stock Honda Chips are ROM chips, AKA Read Only Memory. If that is the case, and I think it is, they cannot be dumped or over written. But they can be read and saved. Then once they are saved outside of the chip they can be edited by a ROM editor. That is why dealership/mechanics can only change simple aspects of the ECU's functions with a stock ECU and scan tool.
FYI, I was able to read an OBD0 chip that I had removed from the board using the burn 1 and the SST chip settings with no problem. I tried to erase the stock chip and was not able to do so..... ROM chip!
Old Jul 11, 2008 | 10:56 AM
SOHFAST94's Avatar
Default Re: (Dxs)
Is it set on 27c256? If not that may be causing your problem. The older chips found in these ecus don't correspond to the newer chips we use for tuning.
hood ride eg
Southern California
Aug 30, 2010 01:39 AM
en00be
Engine Management and Tuning
Feb 9, 2009 10:43 AM
xDicktonesx
Jun 23, 2005 02:24 PM
