Hondata problem s200
Old Jun 24, 2008 | 02:51 AM
jdmland's Avatar
Default Hondata problem s200
Car runs fine, soon as i hit boost i get a cel, just for a sec, then it goes away.
So i datalogg to see what codes i get, no codes, just check engine light and rev limit lite come on just for a sec, then they go out.
Car is only boosted 6psi, My hondata does have boost option, i checked.
There are no codes in hondalogger either.
This is a new setup just put on the car, haven't been to the dyno, is this just some kind of a safety feature till i get the car up to the dyno?, seems weird, car runs fine until u hit boost. Any ideas?
Old Jun 24, 2008 | 08:52 AM
mtber's Avatar
Default Re: Hondata problem s200 (jdmland)
Sounds like you may have a boost cut enabled.
Take the car to your local tuner & get it checked out.
Old Jun 25, 2008 | 06:51 PM
norconex's Avatar
Default Re: Hondata problem s200 (mtber)
Not sure there is any local tuners around the corner in Egypt...but, you could email a Hondata tuner your file to take a look at.
Just look at the CEL Shift light feature and see where it is set and what your boost cut is set at.
Old Jul 4, 2008 | 10:29 PM
jdmland's Avatar
Default Re: Hondata problem s200 (norconex)
Well i found out boost cut is enabled.
Also would i need to burn a new chip just to disable the knock sensor?
Old Jul 8, 2008 | 10:18 AM
Spunkster's Avatar
yes the chip must be reburned in order to make any changes
This is why the s300 is much more user friendly
tgrace
Oct 7, 2003 01:52 PM
legendboy
Oct 3, 2003 09:24 AM
TwistedHatch
Aug 3, 2003 08:40 PM
leed
May 14, 2003 06:45 AM
