trouble programming ostrich 2.0
Old Jul 4, 2008 | 10:02 AM
Powered By Garrett's Avatar
Default trouble programming ostrich 2.0
i got crome, ostrich 2.0, and burn1. trying to burn my bin onto the ostrich via crome (or flash n burn..) but neither work. after messing around a few times finnally got crome to connect to the ostrich (wrong com port). now its connected, but when i try to 'put' on the bin, i get an error: "The operation failed after 3 attempt(s) with 250 milliseconds between each attempt."
Anyone have any ideas?
Old Jul 4, 2008 | 11:21 AM
98vtec's Avatar
moderator emeritus
Default Re: trouble programming ostrich 2.0 (Powered By Garrett)
close crome, reopen and make sure com ports are correct.
Old Jul 4, 2008 | 11:32 AM
Default Re: trouble programming ostrich 2.0 (98vtec)
tried that with all available ports, no avail (port 1, 3, 4, 10)
Old Jul 4, 2008 | 11:38 AM
98vtec's Avatar
moderator emeritus
what setting do you have the ostrich on? I dont have a new one, but a friend of mine got a new one and said the unit itself had switch and it needs to be on the correct one.
Old Jul 4, 2008 | 11:40 AM
theres no switch on mine. maddog20 just helped me, the baudrate had to be changed in crome! i got it now. thanks!
JDM_d15b_eg8
Dec 26, 2006 05:17 AM
JD95hatch
Dec 27, 2005 11:40 AM
Iomega01
Audio / Security / Video
Sep 4, 2005 07:04 AM
nriebeling
Sep 25, 2002 07:53 PM
