AEM Jumper setting question.
Old Jun 27, 2008 | 03:07 AM
technikg60's Avatar
Default AEM Jumper setting question.
What does the JPC1 jumper actually do? I know it is for the ignition driver output but what is the do the different positions actually do?
Old Jun 27, 2008 | 04:28 AM
boosted hybrid's Avatar
Default Re: AEM Jumper setting question. (technikg60)
Sets the coil output for rising or falling edge trigger. JPC1 indicates coil output #1, and so on.
Old Jun 27, 2008 | 05:12 AM
technikg60's Avatar
Default Re: AEM Jumper setting question. (boosted hybrid)
My next question is what jumper setting correspondeds to rising/falling? I want to run this igniter which uses rising edge.
http://www.megamanual.com/ms2/Bosch_124.htm
What do you think?
Old Jun 28, 2008 | 09:30 PM
It depends on what ems box you are using. If you look at the instruction manual for your particular box, it will tell you what the coil outputs are from AEM (rising or falling). There are two possible positions for the jumpers, if the box is rising from AEM, move the jumper position and it will be set to falling. its pretty straight forward.
If you use a CDI ignition box (which you should be), you dont need an ignitor. You can fire to the trigger wire right from the coil output from the ems box.
ral24_hct
Mar 23, 2011 12:57 PM
busdriverj
Engine Management and Tuning
Feb 19, 2009 09:24 PM
solorexer
Jul 3, 2007 03:28 PM
Fulle-loaded
Oct 5, 2004 12:13 PM
