Help troubleshooting ECU check engine circuit
Old Aug 29, 2008 | 08:22 AM
7rrivera7's Avatar
Default Help troubleshooting ECU check engine circuit
I've got 2 P28 ECUs that won't flash the check engine light and the problem is in the ECU. Can someone give me some tips on where to look/test on the circuit board in order to troubleshoot this issue?
Old Aug 29, 2008 | 12:48 PM
93turbo16's Avatar
What do you mean won't flash the check engine code? Does it just stay solid all the time or what is exactly happening?
Are you jumping the service connector properly?
Old Aug 29, 2008 | 12:52 PM
7rrivera7's Avatar
Default Re: (93turbo16)
Yes, I jump the connector with a switch I have built into my harness. I use my car to verify all ECUs I chip before giving them to my customers. The 2 particular ECUs do not send the signal to the CE light so the problem is on the circuit board.
Old Aug 29, 2008 | 01:10 PM
HRTuning's Avatar
Default Re: (7rrivera7)
I replied on pgmfi.org about this. Just click the link I posted in that thread and look at the schematic. It has everything you need to test the circuit completely.
Old Aug 29, 2008 | 02:40 PM
7rrivera7's Avatar
Default Re: (HRTuning)
Got it, thanks
Old Sep 24, 2008 | 04:11 AM
d1jinx's Avatar
HRTuning,
i have not been able to open pgmfi.org. I cannot see the link you posted. can you post a link to it. I am having a problem with a P28 that throws the IAC code 14. I need the schematic to the board. I believe i found the problem but would like to see the Board Shcematic anyway. Thanks.
PHILLIPDEEZ
Aug 13, 2005 11:21 AM
gda777
May 2, 2005 09:11 PM
lilxvtecxpwr
Aug 9, 2002 09:14 AM
