Working on HondataS300 basemap & having problems...
Old Jul 5, 2008 | 07:34 PM
JDM_Honda_349's Avatar
Default Working on HondataS300 basemap & having problems...
Im using the B18c 12Ohm Supercharger calibration off Hondata website with 550cc injectors and Ive it to start up but when I give it fuel it wants to cut out and pop and almost die.Ive cleaned the IACV and running the correct iridium spark plugs. I havent changed anything else except injector size to 550cc. When would it be cutting out and wanting to die on me? Im just trying to get a good enough basemap so I can drive the car to get it tuned and not have to put stuff on the car when I get there and basically just be ready when I get there.
Also, I have a AEM uego wideband and it bounces all over the place and doesnt really stay in a consistant place.When I give it fuel, sometimes the gauge goes blank and then resets...Why would this be?Would it be leaking around the sensor or what?
Thanks in advance for replys and I will keep posting what works and what doesn't but Im looking for some info to get me started and on the right track!!!
Old Jul 5, 2008 | 10:35 PM
mtber's Avatar
Default Re: Working on HondataS300 basemap & having problems... (JDM_Honda_349)
Make sure you are running high impedance injectors WITHOUT a resistor box.... or vice versa..
Look at your intake air temperature readings along with your engine coolant temp readings. Make sure they are on par.
Old Jul 6, 2008 | 09:48 AM
Im running RC550's and there high impedance and no resistor box.
How do I set up a datalog correctly so I can post a datalog?Im trying to do it while the car is running but when I hit datalog and record, its not recording anything...What exactly do I need to do to get it to work??
Old Jul 6, 2008 | 10:09 AM
mtber's Avatar
Default Re: (JDM_Honda_349)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Honda_349 &raquo;</TD></TR><TR><TD CLASS="quote">Im running RC550's and there high impedance and no resistor box.
How do I set up a datalog correctly so I can post a datalog?Im trying to do it while the car is running but when I hit datalog and record, its not recording anything...What exactly do I need to do to get it to work??</TD></TR></TABLE>
Are you sure you are even connecting to the ecu ?
I.e. does the online/upload tab become usable when you are connected ?
Old Jul 6, 2008 | 12:54 PM
Yes. When the ignition is turn to the on position or running it reads "Online".
Old Jul 6, 2008 | 01:03 PM
When I change the current injector size under fuel trim, do I just type in the injector size that Im using and thats it or do I have use the luel trim calulator setup so that it corrects the injector voltage compensation??
The only thing I did when I added my injectors was type in the injector CC that Im using and thats it. If I have to recalulate, what do I do to do that?
Old Jul 6, 2008 | 10:29 PM
mtber's Avatar
Try changing the overall fuel trim to a positive value such as 10 or 20 etc...
Then try -10 or -20 etc...
You can also try contacting the vendor you purchased the unit from for a better basemap to start with. We provide all of our customer's with startup calibrations which actually come from vehicles we have tuned.
Modified by mtber at 2:44 AM 7/7/2008
Old Jul 7, 2008 | 02:31 PM
Changing the fuel trim to those still did not help my setup.Im going to email my calibration to a user on here to look at and hopefully they can look it over and help.
Old Jul 8, 2008 | 10:17 AM
Spunkster's Avatar
Who socketed the ecu? It is also possible that the s300 is not properly seated on the pins.
PR8urVtec
Engine Management and Tuning
Oct 1, 2014 01:54 AM
FlewByU352
13
Aug 23, 2012 06:31 PM
turbotime
Oct 4, 2005 10:30 AM
db8sedan
Aug 28, 2005 10:16 PM
ITR9788
Apr 22, 2005 09:37 AM
