injector help
Old Jul 2, 2008 | 07:36 PM
cvkid15's Avatar
Default injector help
my car is currently turbo on stock injectors. im in the market for injectors but dont know which way to go. the motor is a d16y8 and everything is obd2. i know i will need saturated injectors, my question is if there are any injectors that are plug and play or which clip i would have to buy. thank you
Old Jul 2, 2008 | 09:09 PM
mtber's Avatar
Default Re: injector help (cvkid15)
No aftermarket injector is going to plug & play directly into the injector.
RC makes an adapter clip which allows you to directly plugin a obd2 clip into the adapter which plugs into your aftermarket injector.
You could also always buy cheaper clips & solder them in.
You will need a set of saturated injectors. I would recommend precision or rc 440cc injectors.
Old Jul 3, 2008 | 06:43 AM
cvkid15's Avatar
thanx and yeah those were the clips i was looking at, now with the clips pictured do i buy the honda specific injectors? or do i buy wichever?
Old Jul 3, 2008 | 07:18 PM
ralph11sec's Avatar
Default Re: (cvkid15)
there are a lot of sellers for that injector clip.
xenocron.com has them. i think phearable also. or if you want to save get the clips off obd1 cars @ your localjunk shop you can also modify the obd2 sockets if you wanna diy.
Old Jul 4, 2008 | 09:04 AM
mtber's Avatar
Default Re: (ralph11sec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ralph11sec &raquo;</TD></TR><TR><TD CLASS="quote">there are a lot of sellers for that injector clip.
xenocron.com has them. i think phearable also. or if you want to save get the clips off obd1 cars @ your localjunk shop you can also modify the obd2 sockets if you wanna diy.</TD></TR></TABLE>
Yes we carry everything he needs :-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvkid15 &raquo;</TD></TR><TR><TD CLASS="quote">thanx and yeah those were the clips i was looking at, now with the clips pictured do i buy the honda specific injectors? or do i buy wichever?</TD></TR></TABLE>
Yes you order honda specific injectors.
imationdawg
Aug 1, 2009 07:33 AM
carrnut21
Nov 30, 2007 04:51 AM
oz`Vtec
Jun 15, 2006 05:49 PM
superduperman
Sep 13, 2003 12:37 AM
